Cordless Impact Wrenches?
I use a Milwaukee M18. Loosen the nuts well. However I use a torque wrench for final tightening. The Milwaukee has enough power to torque the nuts but I use a torque wrench so I don’t overtorque.
There are several good makes / models to choose from. I went with Milwaukee as I had several other Milwaukee tools that use the same batteries.
SDGT3 (11-16-2022)
^This.
I'm running the Dewalt 20V Max XR 1/2 cordless impact.
Do you guys find your M18 has enough torque to break the nuts loose at all times? My 991 nuts seem to torque themselves down to absurd levels. I run optimol anti seize paste and torque to 350 ftlb with a precision tools torque wrench (typical street GT3 torque wrench).
After running on track, my nuts torque down to the point that my Dewalt at full power won't break them loose 50% of the time (claimed to have 1200 ftlb of breakaway power). I end up having to use an utterly massive breaker bar, with a 3ft steel pipe for additional leverage.
I just bought a brand new set of nuts from PMNA, and switched my anti seize to the Molykote used on ferrari challenge cars, but haven't had that setup on track yet.
Milw M18 the best I use it all race weekend on 1 battery and remove 350 ft lbs probably 28 times plus the retorque that many times to close to 200lbs (then by hand)
The following 5 users liked this post by Steve113:
Apex Ace (11-15-2022),
carbondan (11-15-2022),
Mike Roblin (11-15-2022),
SDGT3 (11-16-2022),
WhoDat996tt (12-19-2023)
Originally Posted by carbondan
Wow, I wonder what I'm doing wrong that's leading to such wildly overtorqued nuts on my 991?
That's the difference I guess, they talk about a 1" Milwaukee M18. I use the same, also used it in endurance races, perfect tool and always got the wheel nut off.
Booth9999 (01-06-2024)
Did anyone try this? https://www.youtube.com/watch?v=B35VBafGRo4
Different tools for different purposes IMO. The hytorq tool takes a long time to operate. For cup car use where you slam on and go brrp--brrp an impact gun is much, much faster.
I use a Makita 3/4 drive impact. The socket is 3/4 drive and this way I don’t need an adapter. Works fine every time. I have tried a 1/2 drive with an adapter and it would not remove them.
Milwaukee 2867 M18 1". I use this to remove the nuts, works great. No need to have someone hold the brake or wheel.
https://www.milwaukeetool.com/Produc...enches/2867-20
