New Trailer for Cup Car
I currently have a 24' ATC using it for my 992 cup and it is starting to get small for me. I am debating on goin 28ft or maybe just go bigger so I don't have to again in the future with a 34 or 36' gn. Can't make up my mind and maybe you can help since you've had them all.
https://www.dswmanufacturing.ca/2015/11/fold-up-bench/
This is the folding bench I got from dsw.
My 24 ft atc works out to about 3 feet from rear of car to door for balanced pull with gmc 2500.
Maybe with slighty shorter trailer you can go further back and not have tongue weight issues.
awrryan (06-02-2023)
I wouldn't go longer than 28 with bumper either. I do use a 2022 F-450 dually so I am debating what to do with upgrading my 24.
The gooseneck pull nice and a 36 footer is probably the sweet spot for a single car. It's not much longer overall than a 24 tag. You just lose the bed storage and they won't work with a short bed truck.
it's just a balance of logistical PITA versus space. bigger than 24 and you are really only stopping at truck stops, pain if you need to stay overnight in a hotel etc. 24 is already a pain, but bigger is just worse. I ended up with the 32' tag because it was a package deal with a car I recently acquired. I would not have bought a tag that long in normal circumstances, but I have to say it tows better than my 24'. The 32 is triple axle all aluminum, the 24 is steel 2 axle. We had a lot of problems with blowouts on the 24 because we were close to the 12k limit (2x 6k axle) and had. Nitrogen bottles and tool box both on the left side of the trailer which was too much load on the left front. I have a '22 Chevy 2500 as the current tow vehicle.
I just pulled the trigger on the 8.5x20' stealth the other day. It's having a warn winch and versatie track installed down the full length of the floor now.
I'm going to run more versatie track down the front walls, that's about the only place I'll have floor space for storage. Going to do a stack of 4 wheels on a tire dolly and tie that up to the wall. Will do some misc small cabinets for essential fluids and <100 lb worth of tools, and a 2 over 2 fuel jug holder up there.
Kept going back and forth all day yesterday about upgrading it to the 24 foot model they had in stock and trading my 2019 Raptor in for a 2023 Ram 3500 dually or F350 platinum dually.
It's one of those deals where it seems like you can just never have enough space, got to call it a day at some point. My problem is I love the raptor for doing raptor things but on the flip side I tow long distances quite a lot, did two trips from WA to Nor and So Cal as well as salt lake and back just in the last month or so with my open trailer attached. Guess we'll find out how well the Raptor handles the 20 footer and take it from there!
I installed the roadmaster active suspension kit and a Gen-Y Boss hitch last month and it made a world of difference in the ride quality and load leveling.
I am pulling with a F-450 dually which is a long bed of course so I am not worried about the bed length. I am worried if I go gn I lose my bed space which usually I put my coolers, spark wheels in. I am really leaning for a 36' gn customer build by Intech but then I'm also looking at 28' bumper pull. I am stuck between the two.
Floor space wise the 28 tag and 36 goose are the same. It's just trading attic storage in the goose with bed storage. You'll end up putting cools/wheels etc in the trailer vs the truck. I have gone back and forth too. Having the truck bed is kind of nice for things like luggage/etc, but the attic storage in the goose is a lot of space for all the things you usually put in the truck bed. The GNs do pull well and probably get a little better gas mileage with better aero because you don't have the giant wall of trailer 5 ft behind the truck.
I had a raptor myself and sold it for a F-250 tremor. One of the hardest decisions ever because I really loved my raptor and still want another one just couldn't handle the towing I did and I tow more than I offroad. But I did end up moving up from a F-250 to a F-450 later down the line.
How big of a performance difference did you notice going from the 250 to 450?
I'm frequently towing from Seattle to California which has a combo of steep mountains and long straight stretches.
Having a hard time striking a balance between a setup that is solid and stable, without overdoing it with something so cumbersome that it becomes problematic.
My raptor with the roadmaster suspension and Gen-Y non-WDH hitch pulled my open trailer like a dream. More power than I'd ever need, ample brake, and never a hint of sway. The enclosed trailer is only about 400 pounds heavier than my open trailer, but I have to imagine I'll add another several hundred pounds of other stuff now that it's enclosed. The wildcard in my calculation is how the big broad sides of the enclosed trailer will contribute to sway. I think the open trailer gets off easy since the air pressure doesn't build up too much on the broad sides.
Also towing a 20’ with a Land Rover. Trying to keep the weight down as much as possible. The coin flooring has a hefty weight premium. Went the shoring beam route. Does the job and leaves plenty of space for a desk at the front and all my other gear.
Thank you!
Towing the GN is going to be way more stable vs the bumper pull. With the F450 you will be setup perfectly. One thing to consider though is the resale value on a 36ft GN. Most people who are looking for a used GN are looking for 40+ ft. Probably not a deal breaker but its good to consider all possible outcomes.
