Porsche Cup Cars
997.1 Drive Shafts: Current Recommendations
Old 08-25-2023, 08:18 PM
Herb E.
Herb E.'s Avatar
Default 997.1 Drive Shafts: Current Recommendations
A friend of mine snapped the threaded/splined-end of his left rear driveshaft on his 2006 997.1 Cup car this week exiting Turn 7 at the Glen. Not a good experience. I have a similar (2007) Cup and have begun looking at replacing mine as well as his. It there are current preference out there these days on replacements? Looking at the 2007 Turbo driveshafts, the Demonspeed drive shafts, etc. Any experiences are appreciated.
Old 08-26-2023, 08:27 AM
J. Kid
J. Kid's Avatar
The failure was a motorsport Blue Axel
Old 08-26-2023, 08:58 AM
Mike Roblin
Mike Roblin's Avatar
I had the same thing happen to me last year at VIR entering the front straightaway, scary but thankfully not too bad all things considered.
After a bunch of research I decided to go with the Demonspeed axles.
Old 08-26-2023, 10:38 AM
Herb E.
Herb E.'s Avatar
That looks exactly like our failure. It also was a blue axle. Thanks for sharing and for the input.
Old 08-26-2023, 10:50 AM
Dan Jacobs
Dan Jacobs's Avatar
I've used street 996 turbo axles for many years replace every 2 years
Old 08-26-2023, 10:56 AM
Herb E.
Herb E.'s Avatar
I’ve found turbo axles for $850 each from Porsche. Ed’s (Demonspeed) are $3200 a pair. On the website Ed states the shafts flex more to lessen the load on the ends. Makes sense. Not sure if the ends are stronger.
Old 08-26-2023, 11:46 AM
38D
38D's Avatar
Two 6cups with turbo axles had failures at the NJMP race last year. If I needed axles, I’d be buying demonspeed’s.
Mike Roblin (08-26-2023)
Old 08-26-2023, 06:04 PM
Herb E.
Herb E.'s Avatar
Thanks Dan!
Old 08-26-2023, 09:32 PM
Mike Roblin
Ed also states that because of the metallurgy he (or the drive shaft shop) uses the axles don’t time out, all you have to replace are the bearings. When you consider that, they pay for themselves after 2 sets of Turbo axles which shouldn’t be used more than 25 hours.
Of course this is assuming you don’t have a failure that ends up tearing up $10k (or more if you hit something or someone!) worth of your car in the process.
Old 08-27-2023, 11:50 AM
Oddjob
Oddjob's Avatar
It is worth considering converting the early cars to run the later green/yellow axles?
Are the 997 Turbo/GT3/GT2 axles any better than the 996 Turbo axles?
Old 08-27-2023, 10:14 PM
Ed@Demonspeed
Basic Sponsor
Ed@Demonspeed's Avatar
We have been supplying these axles for the 996 and 997.1 cup cars for close to 10 years now. We sell quite a number of the DSM version of the drive shaft shop axles. In that time, there have not been any snapped axles. Unlike the factory axles, both the inner and outer bearings can be serviced. The outers require a return to DSS for them to perform the service, but it is quite reasonable.
Ed
https://demonspeed.com/
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
Old 08-28-2023, 10:50 PM
Herb E.
Herb E.'s Avatar
Ed
thanks for the additional details Ed. I see on the website the splines on these shafts are have been upgrade 36 from the stock 28. I assume that there special hubs that need to be ordered to mate with these shafts? I didn’t see them on the website.
Old 08-28-2023, 11:15 PM
Ed@Demonspeed
Basic Sponsor
I really thought we removed that comment from the website to avoid confusion. That is between the axle shaft and the bearing, not the fit of the axle itself.
No, nothing extra needs to be purchased or changed.
Ed
Old 08-29-2023, 12:22 PM
Herb E.
Herb E.'s Avatar
Ed
Thanks for the clarification Ed!
Quick Reply: 997.1 Drive Shafts: Current Recommendations
