997 CUP coolant pipe failure
https://rennlist.com/forums/porsche-...n-997-cup.html
I am trying to conclude if the coolant pipe design / adhesive is common between road GT3’s and Cups. There is a ton of info on GT3’s but very little specific info on Cup cars likely due to lesser build quantities. I am specifically interested in the 2nd Gen 3.8 which I have read may differ from the 1st gen as the adhesive was improved. The only info I found is attached which is from 2018.
My questions
1. Is the coolant line design common between 7.2 GT3 and 7.2 GT3 Cup
2. Is it recommended to have Cup coolant line modified, weld or pin
3. Do HPDE or race org require the modification
My questions
Well at over a hundred views and zero responses I will assume that I am over thinking this one.... not an issue on 7.2 Cups... unless someone says otherwise
My 997.1 cup had a failure in the epoxy after a motorsport rebuild. Caught before catastrophic failure. I had the motor pulled and welded in sharkwerks couplers.
Basic Sponsor
Yes, these parts and the adhesive is in common.
Very few cups has suffered this fate. I would more attribute this to the lack of heat cycles for the adhesive. While a street car may see 500 heat cycles of the engine in a year it would take more like 5 to 10 years for a race car to see that many heat cycles.
Ed
Ed
https://demonspeed.com/
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
ed@demonspeed.com
My questions
My questions
I can’t help you with questions 1 and 2.
I have been researching pinning the lines as I plan to do it myself. I stumbled on a comment by Sharkwerks that the cup cars are different and have a threaded connection (see first paragraph in the screenshot)
https://www.sharkwerks.com/tech-arti...gt2-turbo-cars
