FS: New set BBS motorsport wheel gaskets and rings for 18"
Are the gaskets replaceable on the rings or are these all one part?
The current style single large O-ring gaskets can be replaced separately on existing rings.
The older style small double O-rings were glued into the spacer ring, and not easily replaced.
Thanks for clarifying. I’m assuming these are the older style ones then, correct?
The ones advertised above are the new style (the design change was made maybe 10+ years ago). Pretty sure you can't get the old double o-ring seals anymore.
If you have the old style and are rebuilding the wheels, you would need to buy these full new seal ring assemblies. The old style rings are different and you cannot use with the new o-rings.
And if you damage a wheel and are replacing one or more of the rim halves, you may want to use a new seal ring, as they can be bent or warped.
Basic Sponsor
I am assuming the sale went through, so I wanted to jump in on this and let everyone know that Demon Speed stocks the newer style BBS orings. As well as new hardware. So, if you are looking to rebuild, we have the parts for you.
We can also offer the full gasket assemblies, we just do not stock them like we do the gaskets.
Demon Speed also have an assortment of sizes for the wheel halves as well.
https://demonspeed.com/?s=bbs&post_t...&type_aws=true
Ed
Ed
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
ed@demonspeed.com
zbomb (11-28-2023)
