Porsche Cup Cars
When half-shafts go bad (pic).....
Old 09-25-2007, 02:39 PM
jrgordonsenior
jrgordonsenior's Avatar
Default When half-shafts go bad (pic).....
Just thought you might like to see what a broken half shaft looks like....
Old 09-25-2007, 02:40 PM
Geoffrey
Geoffrey's Avatar
That isn't too bad, how does the underside of the car look?
Old 09-25-2007, 02:58 PM
jrgordonsenior
Remarkably unscathed. He even drove it back to the pits!....
Old 09-25-2007, 03:04 PM
AndyT
AndyT's Avatar
Yikes well theres 2500 hundred beans out the door. I am using the solid black axles. Probably won't ever pony up 5 grand for the lighter blue ones.
Old 09-25-2007, 03:06 PM
mklaskin
mklaskin's Avatar
I had a similar experience with my 993. A previous owner had installed street half shafts and they just twisted themselves loose over time. Driving back to the pits was not an option...
Sorry, no pics.
Old 09-25-2007, 03:07 PM
jmreiser
jmreiser's Avatar
Note the wheel & tire size that the axle is laying on. That is GT3R/RS/RSR stuff, not Cup. Maybe that was a factor too, if that was all from the same car.
Old 09-25-2007, 03:16 PM
Geoffrey
Geoffrey's Avatar
You can always use a Cartridge axle at 11k per pair. They last much longer than the blue or street axles.
Old 09-25-2007, 03:37 PM
jrgordonsenior
Good eyes Jim but it was an 05' cup with stock rims & tires. I wondered if anyone would notice that....
Old 09-25-2007, 03:58 PM
kev
Darth Cup
kev's Avatar
Any idea how many hrs on the blue axle?
Old 09-25-2007, 04:30 PM
jrgordonsenior
Kev less than 80 hours on the car total. It's an 05' Cup that ran a few races inthe first IMSA GT3 season and a few Club races. It has been sitting until just recently....
Old 09-25-2007, 04:51 PM
BC
BC's Avatar
For 5k per set of axles, it would seam like it would be cheaper to make your own!
Old 09-25-2007, 05:48 PM
leif997
leif997's Avatar
Geoffrey, can you expand a bit on the Cartridge axles? what makes them so much stronger? source? Do you think there is an inherent error factor if one uses a blue and a black if one is forced to mix a spare black at trackside?
Old 09-25-2007, 08:06 PM
Austin
Austin's Avatar
Causes of broken axles:
1. Accelerating hard while rear end light (suspension extended) or after catching air over birms
2. Accelerating before car completely dropped from air jacks in hot pits
3. Excessive standing starts
Please add your favorites and we can all learn from each other:
Note, once an axle has been used on one side, it is only a spare for that side. Splines will wear, even if not visually detectable from regular eyesight.
Old 09-25-2007, 10:43 PM
Geoffrey
Geoffrey's Avatar
Hi Norm,
The Cartridge axles are built by a company Robert Linton owns and have been used by many of the ALMS teams in the RSRs. The axles have a high quality CV joint and lightweight axle assembly with cooling designed in. They are made from material like titanium, 300M, ceramic *****, etc. I know Chris Cervelli has been running them on their RSR and have been more cost effective to run over the Blue axles even at 11k initial price.
Here is a link to the source http://www.cartridgeltd.com/productl...ID=8&pstrPID=8
Old 09-26-2007, 04:13 AM
NJ-GT
NJ-GT's Avatar
What about these ones. $2,400 sounds pretty good.
I was considering them to run SCCA ProSolo events this year (at least 12 Drag Racing starts per event). Last year a GT2 and a GT3 broke axles at the SCCA ProSolo Nationals.
Link Here:
http://www.evoms.com/marketplace/Vie...874FFA1D513%7D
Quick Reply: When half-shafts go bad (pic).....
