Porsche Cup Cars
PS Line Removal Help
Old 07-31-2016, 06:24 PM
North Coast Cab
North Coast Cab's Avatar
Default PS Line Removal Help
I have a small leak around the Power Steering reservoir where the return low pressure line enters. The red sleeve is all chewed up too....
Anyone had an issue like this or have an idea how I can get it apart?
Old 07-31-2016, 10:22 PM
LQQK
LQQK's Avatar
Yes. This happens a lot and unfortunately it's difficult to repair without replacing the entire power steering reservoir.
I ended up putting in and an8 fitting and cutting the line and using an 8 an push lock fitting. This solved the leaking issue.
Old 08-01-2016, 08:00 AM
North Coast Cab
So how did you get it out? I actually have another reservoir, bushings etc. but can;t get the line out.
Old 08-01-2016, 04:32 PM
911racer
911racer's Avatar
Think he is saying that he cut the hose and added the an fitting to the cut hose end.
Then drilled and tapped the cap for the opposing fitting.
Quick Reply: PS Line Removal Help
