wheel nut tightening torque - is it really 470 ft/lbs?
Old 10-01-2005, 01:40 PM
garrett376
garrett376's Avatar
Question wheel nut tightening torque - is it really 470 ft/lbs?
Hi guys/gals,
I was at Discount Tire getting some tires for my 911, and saw on a sheet that the Carrera GT's wheel torque value was listed at 470 ft/lbs. Is this correct? I'm just curious, and I figured you guys should know!
Old 10-01-2005, 02:21 PM
themarsman
themarsman's Avatar
No it isn't 470 ftlb.
You are supposed to tighten wheel nut to 550Nm (407ftlb) + 25 Nm (19 ftlb).
Old 10-01-2005, 07:09 PM
IcemanG17
IcemanG17's Avatar
Here one way to look at it...most of us have 5 nuts at about 96ft/lbs or 480 ft/lbs...so one nut with 407ft/lbs seems about right?
Old 10-02-2005, 12:07 PM
Woodster
Woodster's Avatar
The dealerships have a special "torque multiplying wrench" for doing this,
otherwise you would need a very long breaker bar!
mk
Old 10-02-2005, 01:37 PM
garrett376
garrett376's Avatar
That's cool, thanks for the info, guys!
Old 10-02-2005, 02:19 PM
SPR
SPR's Avatar
I was actually told by the mechanic, because the locking tabs weren't clicked out on one of the collars, that you use the torque multiplier and with that you can use a regular torque wrench. Dunno how much truthful that is but I am sure the manual would cover that.
Old 10-11-2005, 10:04 PM
Steve N.
Steve N.'s Avatar
Iceman: My CGT has four nuts; other street Porsches have 20, but I only have two - last time I checked. Same as most guys.
Sorry - couldn't help it. Others have shown proper restraint.
Old 10-13-2005, 01:30 AM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
The "torque multiplier":
A = (Ta - Tw) * L / Tw
A = Length of adapter needed, in inches
Ta = Required torque at working end, 407 ft/lbs.
Tw = Torque wrench reading from its scale, 250 ft/lbs
L = Length of torque wrench, from handle center to drive center, 18"
using my large torque wrench I'd need an 11.3" extension :
(407 - 250) * 18 / 250 = 11.3"
Quick Reply: wheel nut tightening torque - is it really 470 ft/lbs?
