CGT Repair Manual
Old 03-29-2013, 12:56 PM
JJE997.2RS
JJE997.2RS's Avatar
Default CGT Repair Manual
Anyone have access to one? I understand its not something that would be readily available digitally. Would be ok with a parts diagram even.
Trying to change the alternator on my old man's car. I don't see how it is possible without removing the water pump as well.
TIA in advance.
Old 03-29-2013, 05:42 PM
hoggel
hoggel's Avatar
TIA in advance.
Here's a link to the parts catalog. Good luck.
Porsche Original Parts
Old 03-29-2013, 05:49 PM
JJE997.2RS
JJE997.2RS's Avatar
Awesome man thanks!
I didnt know that was available.
Old 03-29-2013, 05:50 PM
XR4Tim
XR4Tim's Avatar
The parts catalog may not be much help, since it shows the alternator by itself in the Electrical section, and the water pump in the engine section. The water pump diagram may help some.
Old 03-30-2013, 02:27 AM
Crabman141
Crabman141's Avatar
Post a DIY on the CGT, you never hear of those
Old 04-01-2013, 04:02 PM
JJE997.2RS
JJE997.2RS's Avatar
Took all the underpanels off. Confrimed need to remove the water pump as well. The top bolt is too long and won't clear the firewall. The alternator is actually mounted to the water pump, so water pump is going to come off, put the alternator on, replace some gaskets and everything goes back in.
If anyone wanted to replace their A/C pump, that's a breeze!
Quick Reply: CGT Repair Manual
