918 vs P1 vs Duc
#33
That's true - and there will be many more mechanics that will understand battery tech vs engine.
Key factor will be the weight and setting up the car.
The difference between the three super car choices Porsche is the only one that can adapt.
Cayenne in 2015 will have a plug in - things are changing ATM's will be replaced with charging stations
#34
The 918 motor cannot survive without the hybrid system. It was designed without any power takeoffs, every pump are driven by electric only. It also has pathetic low end pull as all the power are tuned to stay up stairs, not very useable on itself for street use.
The 960 might get the Cayenne/Panamera V8 or a V6. Chances of them developing another V8 just for the 960 is slim to none.
#35
I am a Porsche guy and would pick the 918 over the P1 as well. But the P1, at least in a drag race environment as expected given the hp/weight rations, is simply the faster car. Why is that so hard accept? Who cares that it is faster? Would that really matter if you had the money to buy one? It's funny to read comments where people try to find excuses why one is faster than the other or accuse car magazines of taking sides.
#36
These seem fixable issues. Porsche is a master at leverage existing design to create high performance solutions with minimal cost. Remember that the 918 motor doesn't stand alone, but is instead part of the F1 > CGT > RS Spyder > 918 > 919 Hybrid evolution. Within this family Porsche was able to make a huge range of high performance configurations based on shared basic 90 degree architecture, head geometry, etc. With this in mind I see no reason to believe that family can't evolve slightly further, addressing issues like low end tractability or ancillary drive without breaking the bank or creating an "all new" engine. If they so choose...
Actually the CGT V10 is a 68 degree FYI.
Just because they are all 90 degree Vs means exactly nothing. American V8s are all 90 degree too.
918 does stand alone, just like the RS Spyder V8, the CGT V10 and the F1's old V6 Turbo all stands alone. There is nothing common among them apart from they all spin a crank shaft.
Porsche said they had based the 918 V8 on the RS Sypder, but they ended up recasting a different block with a different capacity, pistons, head design, removed all power takeoffs, etc, only thing common was the flat plane design.
I know a lot of people are hoping to see that V8 in a normal car, but it's not going to happen, ever. I had already asked a few Porsche execs during my visits to the factory. That engine alone is worth more than a lot of expansive cars, and with it being hand built there just isn't any capacity for mass production.
#37
Technical Guru
But notice how many of the massively souped up Lambos use their own natural brakes to stop and most of the American cars use parachutes? It goes to the single minded nature of the contest which produces cars that are perhaps fun to watch in a drag race, but not much else...
#38
The evolution from F1 V10 > LMP2000 > Carrera GT was nicely written up in July's Pano. Getting from the LMP2000 project in 2000 to the RS Sypder's V8 is trickier, largely because of the secrecy around the LMP2000's demise. However the MR6 popped up five years later with a nearly identical bore and layout, minus 2 cylinders and a wider V. From the RS Spyder not only does Porsche claim lineage to the 918 and keep the same architecture, but bore and bore spacing were maintained as the engine grew from 3.4 liters to 4.6, allowing for the same tooling to be used. The fact that nearly every part number changed in this evolution is relatively easy- changing dimensions in CAD is an order of magnitude easier than working CFD, combustion chamber design, oiling, tooling, etc from scratch.
The final jump, essentially cutting the RS Sypder's V8 in half for the 919 hybrid, was noted in Race Car Engineering as Porsche's starting point for the new engine. Sure the block and other bits change dramatically, but if you've got a high performance cylinder/ head package, why re-invent the wheel?
Could the 918 motor be adapted to a 960? Sure. Could something else, say a V8 Cayanne? Absolutely, and in fact I know the guy that adapted that engine to win Daytona, so it's got plenty of potential. He changed virtually the whole thing in the process, however. For the 960 application, I can easily guess which engine he'd rather start from, but time will tell.
#39
2. No more naturally aspirated engines
Using the 918 as an example (because I have one ordered), it won't bother me one bit that my 918 will be outperformed by some $300-400k car made by Porsche, Ferrari, or Mclaren in the next 5 to 10 years. Why? Because none of them will have a NA engine in any of them! Ferrari has already announced they will turbo charged their V8 starting from the new California T, Mclaren is already turbo charging and Porsche will certain continue their turbo engines, even in their 960.
More discussion of the efficiency issue here:
https://rennlist.com/forums/991-gt3/...l#post11704112
#42
I would not bet on the NA engine going the way of the Dodo in this application just yet. Large normally aspirated without hybrid are about the be extinct, I'll give you that. However normally aspirated with hybrid, while more expensive turbocharging, is arguably the best technology for an efficient hypercar, with no drawbacks in terms of weight or fuel efficiency when done correctly. Witness Toyota's TS040 V8, clearly the quicker car with the same fuel allotment at LeMans this year against Porsche's 919 Turbo 4. In fact normally aspirated motors still have the highest peak efficiencies (ie Toyota Prius) and power to weight ratios (ie Atom V8) of any street legal gasoline engines. Turbos have significant advantages in part throttle efficiency and cost which will make them the go-to for the majority of non-hybrid sports cars, but for a hybrid hyparcar neither of these is critical. Thus I think we'll hear NA engines scream in this particular application a little longer.
#43
Well the autoccar full test of the 918 has come out and as I predicted after driving both cars up to 180 the cars are about the same ( if anything the 918 is faster ), 918 is faster in gear , has a more responsive engine , stops better and was faster on track . All that on one set of tyres with a single technician that simply looked at the tyres , put his hands on them and shrugged .
typical Porsche
Again how fast or slow a car feels is very different to how fast or slow a car actually IS
typical Porsche
#44
typical Porsche
typical Porsche
#45
