torque wrench reccomendation
Recently bought a Kobalt for $60 from Lowe's--feels like real quality compared to all the Crapsman junk I've had......using it right now at the Glen GORGEOUS weather for once
Gary
Gary
Addict & Guru
Another vote for CDI. Top of the line quality and workmanship at a reasonable price. I learned long ago to buy good tools - last a lifetime, usually work better and easier and just feel good in your hand.
About 10 years ago I bought a used Proto torque wrench to keep in my track box. I think I paid about $20 and figured if it got lost/stolen who cares. I set it at 96 ft/lbs where its stayed all these years. I periodically check it against my CDI. Amazingly, it's stayed accurate.
Torque wrench recommendation
Precision Instruments split beam: https://www.tooltopia.com/precision-...-c3fr250f.aspx
I agree with the recommendation for the Precision Split Beam torque wrench. Good price(~$150), made in the USA and excellent range of torque capabilities (40-250 ft-lb).
You buy this 1/2 drive tool and its little brother 3/8" version and you have covered the vast majority of fastener torques on any vehicle including lug nuts.
+1. I've been very satisfied with my HF wrenches - I have all three 1/4", 3/8" and 1/2". On sale, about $10-15. Certainly good enough for checking lug torque for all but centerlocks. I even use mine for engine work. I've tested them by comparing with some very expensive torque wrenches and accuracy has never been an issue. The cost makes it a non-worry item to leave out and loan out on the paddock.
I do like beam wrenches when I'm concerned about torque building up as they make it easy to see.
-Mike
-Mike
Are split beam torque wrenches a fairly recent invention?
I'd never heard of them until looking into getting one for my center locks. Been using click types (and unwinding them after each use) for 20 years and never knew there was a better option!
Now I kinda want new split beam ones in the smaller sizes as they're way more convenient.
I have 3 Snap-On Techangles from 1/4", 3/8" and 1/2" covering all fasteners on my 997. Plus it has angle value for the final toque down on head jobs which some application requires. Also another advantage besides not having to reset it back to zero after usage is the ability to use on reverse threaded fasteners. Some people, carry over from the old click type strongly advice not to use it for reverse thread, but after asking Snap On on this issue, they told me the electronic ones can be used on counter-clockwise bolts provided it does not exceed the wrench spec. Yes you do need reverse torque setting on some jobs. Some crankcase bolts, transmission drive train bolts etc require reverse threading to tighten it down. Your center lock is a different issue due to the high values and the use of cheater to achieve the high toque necessary. I'm not too sure if the center-lock hubs require reverse threading though.
Firstly, I'd have never thought twice about using a torque wrench for reverse threads if the need ever arose... which it hasn't. I know you don't use them as breaker bars... but they've all got a reverse setting on the ratchet (the precision one you just turn the head around I think) so there doesn't seem to be any reason they wouldn't work for that.
Now... I wasn't talking about digital ones. I was referring to the split beam ones like the Precision Instruments one that most people use for center locks. I mean... it still clicks... but it works differently. When people say "click wrench" they're generally referring to the ones where you set the torque by twisting the handle until you line up the appropriate marks. The split beam ones have a little dial on them that is really easy to set and you don't need to "unwind" it after. It's just way more convenient.
ACDelco ARM602-4 1/2” Digital Torque Adapter (4-147.6 ft-lbs) with Audible Alert
Wow this is all great info, the precision unit arrived and I feel the need to torque something now. Glad you guys didn’t recommend a plasma cutter!!
now I can pack for the streets of willow and try to fit all the stuff in a 997.2 coupe
thanks again for the help
mike
mike
