NT01 pressure recommendations
Old 04-26-2019, 12:11 PM
David993S
David993S's Avatar
Default NT01 pressure recommendations
What's the consensus for DE hot tire pressures on NT01's? Assume 80 degrees, sunny, warm dry track, on a NB 996 (235's & 275's).
Thanks.
Old 04-26-2019, 12:43 PM
Raider89
Raider89's Avatar
For Cayman, I run 34 hot F&R at most tracks. Also monitor sidewall indicators arrows.
Old 04-26-2019, 01:19 PM
dbbarron
dbbarron's Avatar
997.1 I run 31F/33R
Old 04-26-2019, 01:54 PM
Marc Jannone
Marc Jannone's Avatar
Thanks.
I start at 26 cold and bleed down to 33 hot at all corners. I have thousands and thousands of laps on NT01's and this has yielded the most consistent, predictable tire characteristics.
Old 04-26-2019, 02:14 PM
Blue Chip
Blue Chip's Avatar
32/34 hot.
Old 04-26-2019, 02:38 PM
177mph
177mph's Avatar
33 all the way around in a 996 GT3. 245/305 18's
Old 04-26-2019, 06:32 PM
Quadcammer
Quadcammer's Avatar
Received 1,372 Likes on 794 Posts
I also aim for 33 hot, 986
Old 04-26-2019, 10:32 PM
David993S
David993S's Avatar
Thanks for the feedback. It gives me a ballpark starting point.
Old 04-26-2019, 11:11 PM
matt33
matt33's Avatar
997.1 GT3 and also 33 all round
Matty
Old 04-26-2019, 11:22 PM
Turbodan
Turbodan's Avatar
careful they are slippery out of the box until you have a session or two in them.
Old 04-27-2019, 03:20 AM
powdrhound
powdrhound's Avatar
Received 1,728 Likes on 1,007 Posts
Start at 25 cold and set 32/33 hot. This is on a 996 running 275/35/18 and 335/30/18
Old 04-27-2019, 04:16 AM
jayzbird
jayzbird's Avatar
How much are you all starting at 25 bleeding off to end up around 33? On my 996tt if I start at 25 I end up more like 36/38 f/r. The tires (235/315) feel like they are rolling over at lower pressures.
Old 04-27-2019, 08:38 AM
David993S
David993S's Avatar
I'm a little surprised at some of the suggestions to end up at the same hot pressures front and rear. With several other brands I've used on the 996 I've found 2-3 lbs more at the rear (hot) is optimal.
Old 04-28-2019, 01:24 AM
altonj
altonj's Avatar
We have found 32-33 hot providing good grip on a variety of cars.
Old 04-28-2019, 09:34 PM
Spyerx
Spyerx's Avatar
Received 1,733 Likes on 1,061 Posts
32/33 on 997rs
around same on my 964 in those sizes.
Quick Reply: NT01 pressure recommendations
