Diy painting racecars for beginners -questions
Any goto paint types / brands that are forgiving for a newbie with an imperfect painting environment ? One stage etc...
Especially one that will hold up well given the harsh conditions on the nose?
Will not be painting on bare metal , so a sealer of some type may be needed .
Mixed Paint and used a spray gun a few times before, looking for some advice to improve results on a bigger canvas
Factory paint seems to have superior chip resistance compared to non factory. Are there agents that you are adding to pliancy ?do you only do the non metal parts with the agent mixed in or the whole car
also found previous owner went heavy on the bondo on the nose (968). It was pretty cracked, but the integrity of the nose was good . Not sure how wavy the finish will be without the gobs of bondo
Is there any better way to do a bit of filling on a flexible nose ? Would a bit of fiberglass resin be a bit more flexible?
.... asking for a friend
thanks
thanks
Rennlist Hoonigan
which cost no drachmas
Find a local guy to wrap it. Check out the local short track scene and see who is doing cars. The price will be marginally more than the paint materials and time, but the hassle will be about a quarter.
Kinda going further with the above - you can readily buy and slap on vinyl too, I went this route on my prototype for the high-impact areas for stone chips on the nose. Plus the finish, in 5 minutes of install, is as good as many hours of effort painting... and easy to replace.
For racecar, many of the colors you might want can be found online and cheap in smaller pieces (like 12" x 6'). In my case, bright orange, works really well to protect my splitter.
I hear it's also possible to, for a greater cost, buy color-matched vinyl... but I'd go with the commonly-available cheaper colors on a racecar, just like choosing your paint scheme colors by browsing the racer tape selection...
If you go the paint route head to your neighborhood auto paint store. They will set you up with everything you need. Primer, color then clear is what I have followed over single stage paints. It is all in the prep, not the application. The clear holds up well and comes in different hardness. Clear bra on top of that for the high impact areas. You can also wrap, much less durable but just as effective.
I've heard that a decent wrap job is several thousand dollars, even for a basic design?
OP - what's the budget you have in mind?
Not sure where you're getting your wraps done Matt but out here in Denver a basic wrap is easily $2500-3000. I was drooling over a Gulf liveried 997 Cup Car at our Club Race, it was a wrap and it cost $6000 (!!) to do!
Rennlist Hoonigan
We wrap for about the same as paint materials. Find the guy doing the local short track cars. I don't doubt a printed Gulf wrap would be $6k. I'm talking single color wrap and then you put your stickers on it.
For us guys racing low-powered cars, what is the weight comparison of a wrap versus paint (which weighs a surprisingly large amount)?
EDIT: A little bit of Googling goes a very long way. A typical car paint job weighs about 10-14 pounds, and a typical wrap weighs about half as much, which is why serious race-cars are wrapped, not painted. A plain-Jane wrap job costs about $2000.
thanks
thanks
Rennlist Hoonigan
Top level stuff is starting to go Aeropaint. The wrap is lighter, cheaper, and allows more creativity for less than paint would cost to do the same job.
DIY Wrap
Check out Wrap Institute web site for some video training for DIY. Buy some wrap and practice 2x2.5ft squares over curves, concave area, etc. with some practice and patience, at 10ft looks good ;-) for track car/HPDE duty.
A DIY wrap effort, over Arctic Silver 3M1080.
I Wrapped a car already , want to play with paint
Last car had a very minimal surface issues, and was pretty happy with the results as a newbie wrapper. I figured out pretty quick what to avoid as a first timer
the new car has lots of small flaws I wouldn’t wrap over without fixing
this is a bucketlist task...started detailing at 14 -burned plenty of paint with the old school wool pads , wet sanded and prepped a few cars and did a few panels prep/paint / polish... mostly trial and error...hence looking for wisdom outside of the YouTube and its ‘subscribe to my channel’
I expect to use wrap for anything beyond the primary color
Fyi
went to Eastwood store today, had some good info, their website videos are tolerable but don’t cover the questions I’m still stuck on
Fyi
Rennlist Hoonigan
What are you stuck on with painting? I'd suggest primer, paint, thinner, reducer, and hardener from a local supplier. Get the best gun you can afford for this project. Dry air, mix it up, and spray.
And get mixing rulers not cups.
