Brake Pressure Sensors (2,000 psi) for AiM available
Rennlist Hoonigan
which cost no drachmas
Brake pressure sensors have been a problem all year. I've put together these quality 2,000 psi pressure sensors. They feature the same Binder 719 connector, 1/8 NPT port, less than 1% full scale accuracy, and fully compatible with with brake fluid, motor oil, trans fluid, hydraulic fluid, and a host of others.
https://trailbrake.com/tb2000/
If you need oil pressure, I have quality sensors available for them as well https://trailbrake.com/trailbrake-15...essure-sensor/
I assume still no way to get an solo dl2 to read one of these?
Basic Site Sponsor
Basic Site Sponsor
Received 2,879 Likes
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Basic Site Sponsor
Basic Site Sponsor
I don't think I've ever seen it in the field, hence my answer.
Rennlist Hoonigan
Yes, AutoSport Labs AnalogX, AEM's 6 and 22 channel converters, there are things that can be made to work... As you say, it would cost more than a unit that accepts analog inputs, like the MXm. Then building an .xc1
But, I don't want you to derail my thread. It took me a lot of work and weeks of planning to get these sensors together and available. Now all the people who have been waiting for brake pressure have a solution. A nice package went out to one of the Mazda teams today.
I've got a 997.1 cup with a can bridge going to an aim smarty cam GP. Currently using G forces to show braking since the car didn't come with brake pressure sensors when i bought it. Would this sensor work for my setup or do I need a different sensor?
Rennlist Hoonigan
Maybe. If you have a ECU bridge, then you need the data going into the ECU that the camera system is connected to.
Basic Site Sponsor
Basic Site Sponsor
You could add these sensors (would do two on a Cup car) to the MoTeC AN (analog) inputs to read and log.
To send that info to the SmartyCam, add the camera template (VCS_CompoundFull_Transmit) to the same CAN network as connected to the MS3 ECU for engine info in the MoTeC dash configuration.
Then, change the ECU Bridge config to look for the MoTeC VCS template and you would get throttle, brake, gear, steering (if it has a sensor for that) and other channels.
Simple, and quite common. PM me if you’d like directions.
Was in the process of piecing together a workaround with the AIM 160 bar sensor and a M10-to-1/8NPT adapter I found on Amazon. However, this looks like a much better solution.
Rennlist Hoonigan
Just placed an order. My AIM sensor failed last weekend, spraying SRF all over my SPB's front trunk.
Yes, if you have a MoTeC or other logger in the car now.
I have this bundle of wires next to my master cylinders. I'll put in an order for 2 of these sensors. Braking at or near the limit in this car has been the most difficult transition coming from an Abs equipped street GT3. I'm hoping these sensors and the data they provide will help me as I progressively explore the limits. Thanks for the help!
This is the bunch of wires. Based on proximity to master cylinder I'm hoping these are what I need to connect to the Motec. Also in the pic is the red cap for plugging in the sensor.
A follow-up on Matt's sensor:
I received the sensor very quickly -- it shipped the same day I placed the order. The sensor screwed right into place, and plugged right in. It works exactly as described.
However, there are two minor caveats: First, the sensor is nearly 2" longer than the AIM sensor, so you need to make sure you have space for it. Second, this sensor takes 5V power, unlike the AIM sensor which takes 12V power -- this is not a problem if you are connecting it to an AIM system, since the AIM wiring supplies both voltages. However, I am running a VBox HD2 with a micro input module and had only connected the 12V wire (red) to the sensor. I called Matt and left a message, he called me back rather quickly (on a Saturday!) and confirmed the sensor needs 5V; once I hooked up the 5V wire (blue), everything worked as expected.
Matt Romanowski (07-25-2022)
Will be hooking this sensor up to my cup loom to feed into motec. Plan is to cut off the 4 pin Aim connector and separate the wires. Matt could you confirm:
1. Which color wires on these sensors are for a) power. b) ground. c) Signal.
2. There is a 0-2000psi calibration tables in motec. Can I assume the output is linear for these sensors
3. I'm assuming 0 volts=0psi. What is the voltage output of the sensor for 2000psi?
