Where is the suspension data hiding?
You don't need any of the information you are trying to find to tinker with your suspension setup. Porsche already has the car in the ball park. If you want to increase spring rates, find out what spring rates and sway bars the the shops that are supporting 718 GT4 street cars are using to make the car more track worthy. Find out if they are replacing dampers and what dampers they are using. Then all you need to do is adjust sway bars and turn some ***** on the dampers to dial the car in.
Do you turn your car over to a shop and just let them do what they do?
http://forums.pelicanparts.com/porsc...ing-rates.html
That thread took an eerily similar direction as this one is. The desire to understand the quantitative change a swaybar makes is a good question in my opinion - I would want to know the effective rate as well.
You don't need motion ratios and frequency numbers to tinker with the car. In fact, I would argue you probably don't have the tools to properly use that information to setup the car. Hell, I bet only the Factory has the information and tools needed to properly model the 718 GT4 street car. You don't need that information to tune the car anyway. If you know what the car is telling you as a driver, you can make the changes necessary to make the car better. Do you have enough experience to driving to know what the car is telling you? If you don't, having the motion ratios and frequency numbers are not going to be of much use anyway.
My car? The person that built it 12 years ago gave me a car with a known "good" setup. I drove it for 3 or 4 years changing nothing but tire pressures and sway bar settings. Once I learned how to drive, I started changing the car. In the last 8 years the car has been massively changed and I have done all of the development work on the chassis.That would include tires, tire pressures, alignment, dampers, springs, sway bars, ride height, rake, etc. All on my own.....I did outsource welding, engine, and gearbox work because I am smart enough to know that professionals are a lot better than I ever could be.
No one said I'm going to reinvent a wheel, or setup a car better than the factory. Those are not my goals or presumptions.
The disconnect here is that racers are trying to provide practical information that can be implemented in the short term. The OP is interested in science project primarily for learning and eventually long-term improvement.
I don't think you're going to find all of the information you're after posted on the internet. Most enthusiasts aren't digging that deep and wouldn't know what to do with the numbers if they had them. It's not the kind of stuff an OEM or shop is going to share freely. You're likely going to have to take some measurements, make some calculations, and some assumptions, to get what you're after. Some things, like CG, aren't too hard to measure.
edub (03-27-2023)
OP - if you are interested in digging into data and doing some modeling, you can try a suspension modeling program like susprog. I used it years ago to do some suspension redesign. I'm sure there are other programs now to choose from. Susprog is targeted at designing and fabricating suspension, but it can be fun to model an existing suspension setup to see what it's doing. You'll probably have to do some legwork getting the measurements to plug in. For those more interested in the end result (a good handling track car), you might be just as well off choosing components based on recommendations as I'd guess for a platform like yours that information shouldn't be hard to come by, but data may help influence decision making. Enjoy the journey if you wind up pursuing it!
edub, I went down a similar path and enjoyed reading and learning from this classic:
The theory, math, and practical examples are well connected, and you can easily take the measurements you need to build your own simple models and tinker with the concepts. If you're just doing this to learn and to explore then I wouldn't get too wrapped up in the accuracy and precision of your measurements. Get them in the right ballpark and move on so you can focus on what you're trying to learn.
How to Make Your Car Handle: Pro Methods for Improved Handling, Safety and Performance: Puhn, Fred: 0075478000012: Amazon.com: Books
edub (04-10-2023)
Basic Sponsor
My suggestion also is post this question in the Data Acquisition …. Sub forum. All the data guys hang out there and are not (usually) so judgmental as they are here.
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
'07 SPC
'71 914/6 Huey
'04 GT3
Bob Saville
704-395-2975
- Data Analysis & Coaching
- Drivers Gear
- Crew Gear
- Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
https://rennlist.com/forums/718-gts-...ion-ratio.html
TLDR
Method 1 - measuring suspension pickup points - Rear Motion Ratio was 0.78
Method 2 - measuring damper movement - Rear Motion Ratio was 0.75
Didn't measure the front yet
TLDR
ProCoach (04-10-2023)
TLDR
TLDR
