In car Communications with instructors- Stilo helmet
I have a Stilo helmet with built in communications. I believe the female plug on the Stilo helmet is 1/4"(6.35mm), and I'm trying to make sure that i can connect to whatever system my instructor uses.
- are the 2 prevalent systems Chatterbox and Trac-com?
- it looks like Chatterbox uses a 3.5mm plug what type of adapter would i need to get from my Stilo to the Trac-com?
If there's anything I'm overlooking here, I'm all ears
You'll need a Track com cable to connect with a Stilo IMSA cable.
https://www.apexperformance.net/prod...-com-intercom/
https://www.ruggedradios.com/product...l-cord-adapter
No affiliation with either vendor - just showing the product. Depending where you are in Ohio, try calling Tim at Track First in Akron.
mongolikecandy (10-17-2023)
Trac-Com sells a Stilo-specific adapter cable that plugs right into your helmet
We have the adapters in stock. Feel free to call if your locals don't have them.
https://www.apexperformance.net/prod...adapter-cable/
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: info@apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist on your next order or mention Rennlist during your phone order.
Visit us on Facebook
ApexPerformance.net
The mic in the stilo helmet may need positioned closer to your mouth. The cheek pads pop out and the chin pad is velcroed in. You can remove it, gently push the mic out of the liner a little more.
