Jack with about 2" lowest height and 20" raise
Hi All,
I'm looking for a jack for my formula cars so that I don't have to roll it up on 2x4 to get a jack under it. I already have a quick lift formula style jack which works well but gets the car about 6-7" off the ground.
So I want one that has a very low clearance like 2" but can also get up to at least 20" raise. All of the Harbor Fright stuff is a min of 3.3 inches. I've had a Griot HD jack for years which is now dead. It was exceptionally low.
Please no jokes about jacking and using wood.
Rennlist Hoonigan
which cost no drachmas
Why not just rebuild the cylinder in the Griot jack?
I would advise to get a decent jacking in before you have people over. You don't want to look like a rookie when it comes to jacking thingoff up.
Coochas (12-17-2023)
WRONGLY ACCUSED!
Received 3,378 Likes
There's a guy in North Bundaberg who is selling what you need.
The following 2 users liked this post by LuigiVampa:
Coochas (12-17-2023),
wellcoached (12-21-2023)
I just found Pit Boss jacks which are under 2 inches but $2000. Um, no.
mlct (12-18-2023)
Second rebuilding the jack you have if you are happy with it. Check with the manufacturer or hydraulic rebuilders who service your brand of jack.
I don't have any good jokes to add, looks like the others have it covered!
Hi All,
https://www.harborfreight.com/15-ton-ultra-low-profile-lightweight-high-performance-aluminum-racing-jack-with-rapid-pump-58811.html
Claykos beat me to it!
There is an ultra low harbor freight jack that goes around 2.5". It only has around 16 max height though. I have one and it works pretty well. I think they are $300.
https://www.harborfreight.com/15-ton...ump-58811.html
Aside from putting something under the wheels I can use my quick lift to put down 6" chassis stands which then gives me ample clearance to use the big floor jack to lift to 20."
I'm just looking for a short cut.
And I will look into getting my gigantic Griot jack fixed. It puked all of its oil out.
Dave,
I found these two products when I was looking but I am not sure either is still available
https://otctools.com/products/2-ton-...ra-low-profile
Out of stock everywhere I looked now
Hard to tell if these guys are still in business
Brunnhoelzl Pro Flat Jack
Seems to be for sale here but I have ever purchased anything from them
https://www.portcityracecarsus.shop/...ity-race-cars/
I like AC Hydraulics but their lowest is over 3in
Good luck.
Mark
Good luck.
Mark
Dave,
https://www.amazon.com/OTC-5200-Capa...ct_top?ie=UTF8
Good luck.
Mark
Good luck.
Mark
mlct (12-18-2023)
Received 1,455 Likes
mlct (12-18-2023)
Rennlist Hoonigan
This has 2 1/8 clearance and is available. Put extra air in the tires https://behrents.com/parts/hellraize...track-jack.asp
mlct (12-18-2023)
Hi All,
When not racing, we keep my car on transport wheels, which are basically 20" motorcycle wheels & tires: https://www.rsport.us/Rsport_Transport_Wheels.html
You can put any kind of jack you want under the car when they are on transport wheels. When on race tires, we just use a 1/2" board to raise the front up enough to use the MK Technologies nose jack: https://www.mktechnologies.com/
MK Technologies does have some formula car lifts are not very portable, but go very high. That might be what you want.
Take a look at the Arcan XL2T. Here's a listing on amazon: https://www.amazon.com/Arcan-2-Ton-Steel-Profile-A20016/dp/B007G83T16/ref=sr_1_3_sspa, but you can find it at other places too. Goes from 2.75" minimum height to 24" max height.
I've been using a pair of them in my garage for many years, and have been quite happy with them.
Coochas (12-18-2023)
