Brake cooling via NACA ducts
I am planning to install ducting to bring fresh air to the inboard side of the front brakes. While I haven't fully mapped out the layout, would the ducts be more effective if their outlets were directed at
My initial assumption is that the directing the ducts at the caliper is more effective as this is where the heat resulting from the friction of the pads against the caliper originates. OTOH I can also see a benefit to the rotor passing through a stream of air as it rotates. I think directing at the eye of the rotor may be a compromise if securing the duct to point at the other 2 locations is not feasible.
I am open to being educated.
TIA
/alex
- the "eye" of the rotor
- at an unobstructed area of the rotor
- at the inboard side of the brake caliper which (obviously) sits at approximately 1/2 the rotor diameter along the rotor perimeter?
TIA
/alex
What he said. It's the bigger heat sink part of the assembly. Into the eye with something that guides the air toward the internal cooling vanes.
Fred Puhn: The Brake Handbook.
SETaylor (03-28-2024)
962. Very large hose. Cooling is for rotors AND wheel bearings. Ground effects = wheel bearing heat.
The following 2 users liked this post by R717:
delirium45 (03-31-2024),
JRitt@essex (03-28-2024)
Jeff Ritter at Essex co-authored a very informative article which would be worth your time to read:
https://www.essexparts.com/news-blog...n-my-track-car
