Tracking car with suspension fault and without sport mode
I have been driven nuts by a suspension fault that had been coming and going but now doesn’t want to go. I have big $$$ invested in a 3 day DE starting on April 12. I’m curious if anyone has driven on track with this fault showing and how the car’s handling might have been affected, including under hard braking. Since this fault cancels sport mode, I’m also curious about anyone accustomed to the auto throttle blip had to adjust their driving. Many thanks.
As someone who just totaled their car and is incredibly lucky to not be seriously injured because of a mechanical failure on SOMEONE ELSE’s car, please don’t take your car on the track if it has problems. Especially problems of the “I have no idea how the car will respond” variety.
The following 2 users liked this post by amurph182:
ldamelio (03-27-2024),
Rig.Stunts (03-27-2024)
I go to the track to have fun and hopefully improve my performance. I don't know how I'd do either if I was worried about this kind of issue. My confidence in the car would be low and I'd be concerned about impacting other drivers around me. Get the car to a qualified shop to follow Frank's advice.
what is the fault?
To resolve the issue, we changed the wheel speed sensor as indicated by the fault code and the wheel bearing for that wheel, but it turned out to be a faulty wiring harness.
In engineering we always say: "Don't leave anything unexplained. It will bite you later". I think it applies here as well. Share with the community what might be the problem or symptoms and you will be surprised with answers. Perhaps it will help to point you in the right direction and understand the problem.
I can give you an example. At the NJMP PCA Club Race in 2023 I ended up with a (wheel speed sensor) fault, that did not allow me to put the car into Sport+ mode. Unbeknownst to me, this also resulted in an ABS fault that caused me to flat spot two front tires in the warmup lap - I immediately returned to the paddock without completing the lap. If I would have continued, I would have probably crashed the car at the start of the race in Turn 1, due to non-availability of the ABS. Just an example.....
I know running short on time , but with so many DSC controllers out there, maybe someone on Rennlist has a spare stock PASM unit they never intend to use again. ? Do you have a 981 GT4 ? or a 718 GT4 ?
Agree it sounds like a PASM controller issue. Suggest taking it to a shop or the dealer with a PIWIS and have them check the system when the car is cold. With the fault how many other systems are effected? Sounds like the car defaults to "Normal" and a softer shock setting. Suspect PADM is also disable to normal. I'd find out how quickly you can get a new PASM controller. I'd think a dealer would replace and easily take it back if it wasn't the real problem. Whether the car is safe to drive at a DE with its known fault is a hard question. The cars handling and your shifting will definitely be effected.
