Problem with Pagid yellows, help needed?
Meanwhile the cotter pin and retaining bolts have turned yellow..
After a little bit of driving and visual inspection I think it’s ok. Below a picture of the setup now properly installed.
Sebro slotted and Pagid yellow RS29
Received 1,460 Likes
Did you give them a good bleed after? Billowing dark smoke from brakes is never a good thing.
Originally Posted by roadie13
Yeah, I have seen more broken studs than broken lugs on track, but I agree that the gain in convenience is significant.
Basic Sponsor
I'd make sure to bed the pads in after that and as others have said maybe sand down the pad material slightly if they were glazed. Just make sure to do it in a uniform fashion, of course.
--Aaron
--Aaron
Studs are consumables. Torque and release again and again stresses the metal. I replace them as routine.
Also the threaded holes in the hub are not made for constant torque and release and the hub is a lot more expensive to replace.
Easier to change tires too
