Towing question....duallie
I currently tow a 24' enclosed trailer with a 1/2 ton pickup, Reese weight distributing hitch with a sway control on one side.
Weight loaded is in the 6-8K lb. range.
I am looking at a duallie pickup (1-ton) and was wondering if I could tow the same trailer WITHOUT the WD hitch and sway bar and have the same or better performance?
The reason is making tight turns with the WD hitch sometimes causes the "bars" to pop off. Would be nice to have steady towing and be able to maneuver in the pits without having to take the bars off.
TIA
TIA
What's your tongue weight ? (how's that for a set-up line ?)
I tow a 24' with a crewcab dually - and I use a WD hitch, as it gives me much better braking, especially in the wet. My bars don't pop off - you may want to talk to the WD hitch manufacturer, as there might be a problem with the install.
24' with a 1/2ton PU ? You have a death wish.
TIA
TIA
I've got a Silverado 2500HD (not a dually). No problem with the WD hitch...as a matter of fact, I wouldn't tow without it! I live at the end of a cul de sac and making the turn around in front of the house is pretty tight. I've never had the bars pop off.
My bars have never popped off during normal driving.
ONLY when truck and trailer are turned at max angle or close to it. Like when backing into a driveway etc.
TIA
TIA
Not sure how much non-towing or hauling you will be doing, but 3500 dually will ride like crap empty. For towing my car on an open trailer use my father's Dodge 2500 V10. No hitch bars and it tows like champ. Ride is nice and smooth too. However drive around empty (bed empty and no trailer) and ride is borderline. It is use mostly for towing so it no an issue, but if you daily drive the truck and tow on the weekends it would better to stay with the 1500 series truck. The ride will be smoother 95% of the time and only a pain when towing as a 2500 will do a better job with that size trailer. However how much daily comfort is worth giving up for towing comfort.
For us the 2500 is overkill for the small trailer, but it gives us the chance to dream about a bigger trailer and not need to worry if the truck can tow it.
Lifetime Rennlist Member
I agree that you have a problem with your hitch / bars. I use the Reese dual-cam and it works great.
That said, I have also towed my trailer (~8,000 lbs) with a 1 ton dualie with no bars and it did just fine.
Thanks for all the feedback.
It sounds like I need to go through the WD hitch and make sure it's installed and sorted properly. Although I did speak with someone before I installed it and he was having the same issue. Although his could be messed up too...
I've test driven the duallie and don't mind the ride empty. I am however more concerned about parking as it will be a daily driver.
I drove the 8.1 3/4 ton Suburban the other day and it had plenty of power. Anybody have experience towing with the 8.1 Suburban?
TIA
TIA
As was stated previously weight distribution in the trailer itself (with cargo) is extremely important. I have seen damaged tow vehicles and trailers because the tongue weight was too great! Broken bolts, sheared welds, and bent frames.
TIA
TIA
I get approx 13 highway miles empty and 11 around town.
