Boxster engine issues
I have a friend that just replaced a regular Boxster engine, and I believe he bought it from Pelican Parts.
One question, are you sure you can rebuild a Boxster motor? Our local independent Porsche guy, says you can't buy parts for either the 986 or 996 engines. Porsche doesn't want anyone rebuilding them but Porsche itself. I have wondered if that is really true.
Bill Seifert
1983 944 Race Car
Bill Seifert
1983 944 Race Car
Originally Posted by NetManiac
Range 1 is "close to redline". Can't remember how close though. Redline is 7200, so I figure that's between 7000 and 7200.
Range 2 is "over redline". With revlimiters, obviously the only way to do this is to mis a shift.
According to the P-guys at the local dealership Range2 is not from missing a shift, but from the mechanical over-rev during heavy breaking-heel-toe. If the clutch goes out to early, the engine will be forced to "over-rev". You can feel this in the engine loading and avoid it by concentrating on the threshold braking release point. Again, real bummer on the engine. Oh and my friend had alot of the range2 ticks on his ECU.
lol...
...seems people like to argue about missed shift vs. engine go boom issues all the time with respect to porsche waterbabies...
.....yet people like to give me grief about running my TIP 993 at DEs... I just smile as I keep up with them just fine and never have to worry about a missed shift or 'overrev'
It you do the math, 251 spark cycles means my engine spent a total of 690 MILLISECONDS at, or above 7201 RPM. Since I did it at least twice lets split that in half, which leaves 345 ms per instance. That's less than half a second, which tells me that however it got over redline I realized it and did what I could to remedy the situation and did it pretty quickly.
Originally Posted by ceboyd
lol...
Yeah, I understand your point. I just found auto/tip just a tad too frustrating to drive on the street, much less that track.
ah.. you didn't learn the little tricks to driving a tip at the track then... it has its own unique way to make sure you get a downshift with a blip of the gas just before you need to accelerate
...hard to explain what I mean but it's a bit counterintuitive and took me a whiile to get the hang of it..... *(just like I'm sure it will take me even more time to properly learn the heel-toe dance once I move onto something else that is manual gear box for the track)
but I can honestly say that I pull OUT of turns faster than any of my 993 stick counter parts (provided they haven't done the expesive trans mod and only the LWF mod on their NA 993) ..the guys with Trans mod I have NOT had the chance to go back-to-back with at the track so I can't comment on their
ability to accerlerate out of a turn compared to my lowley tip
Mike,
Be sure and let us know if you can rebuild the Boxster motor. By the way, how much is a replacement long block from Porsche? I'll be sure and be sitting down when I read your reply.
Bill
Bill
Mike,
I'm in the same boat as you except I got a 2001 S engine relatively cheap as a replacement.
Ask Brad what he is doing with my engine. You might want to consider that.
Bro
Bro
Mike,
Bill
Bill
And yes, I will be digging this thread back up once the swap, and then the rebuild are complete. So keep your subscription to this thread and you will know what I know shortly after I know it.
Originally Posted by bruinbro
Mike,
Bro
Bro
Bro, I guess he finally got a chance to break yours down. Not sure what he's going to do with it now. I'm considering a lot of options at the moment. So we'll see.
Bro
hmmm.. so it sounds like a replacement boxster engine costs about the same as buying a used 993 engine (from what I've seen anyway)... very interesting....
Hmmm, interesting. If I ever get up to IL (or you get down to CA) I'll have to get you to show me how that's done. I am always open to learning new driving techniques, especially if it means making the most out of all these tips I run across.
sure.. just LMK...
..as long as I still have my car at the time
