Tie a yellow ribbon?
the TDC mark also helps to find out when the alignment it way off... like during a race, w/ a door to door contact. not that, that happens in pca races....
but, mostly it looks cool..
Originally Posted by SundayDriver
I have used a taped band for many years and find it pretty useless while driving. Very simply - you should not be looking at the wheel to determine where the car is pointed. What is it good for and why do I use it (at least I did until I ended up with a car that used an open top wheel)?
First and foremost, it is a great reference for analyzing video. With vibration, etc, it makes it much easier to see where you are steering and the degree of correction when looking at video.
Second - It does help with putting a removable wheel back in place.
Originally Posted by Nordschleife
Go teach your grandmother.......
who said anything about using using the band to determine TDC?
Your crapulous comment is redundent.
R+C
R+C
................I was merely trying to add my perspective............
............and I HAVE done one or two alignments..........
........and some cars (like 944's and 928's) DO have a centering bolt hole in the steering rack housing...(that little plastic screw just outboard of the pinion)....
...and to sww914, who has "done hundreds" of alignments....I would have thought that you might have noticed that.......(??)
The hub for my removable wheel can only go on in the correct position. The band on the steering wheel is helpful because I always place the band straight up when I park the car so that it is easy to install the steering wheel when I get back in the car.
It was also useful when I snapped my control arm two weeks ago. When the arm first started to break, the only telltale sign was that the band on the steering wheel was pointing slighly off to the right, despite the fact that the car was not pulling and was handling extremely well. The additional angle of the wheel was subtle at first, and I am not sure I would have known that anything was amiss had I not noticed the band on the steering wheel.
I don't think it helps too much when trying to prevent a spin. If you are looking at your wheel, you most likely have bigger problems.
If you don't have a removable wheel, the band will be of limited use...it is helpful at times to know how the wheels are oriented when stopped. Most of the wheels I was interested in when buying my removable set-up already had the band on them (Mom, etc.), I guess anticipating a removable set-up.
Basic Site Sponsor
Basic Site Sponsor
Geez, and I always thought that the nice thick yellow band was to prevent the wheel from getting all muffed up when you hang it up on the resting hook!
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
Oh... but none on a Porsche? Methinks I'd ask your GOD why he never told you?
To be.. um... fair, I usually don't use it. When I am aligning a car that I have just put together with a new rack, rods, struts... etc., I'll do it. Nice to start off completely fresh and perfect.
I added such a band to my Momo (Monte Carlo) when I installed it... but in blue, to match the car. Just a band of electrical tape wrapped around it... has stayed put for 7 years now.
I find it useful for all of the above. As a reference for installing the wheels, particularly for newbies in my car - I have a matching paint stripe on the column. I have a hex style release, can easily be installed 60 degrees off.
It's very useful for alignments; when the car is up on the rack I can easily see the alignment mark (though I go for the level on the top crossbar of the wheel to get it perfect.
And it was a very nice feature to have this last weekend, when I got tagged hard by a Rustang (Capri, actually, but same thing) and he gave me the gift of 1.5" toe out. It was 2 corners into the race, we were all still side-by-side on a tight track, and very congested - no time or room to think. But it took no effort to notice immediately that the steering wheel was off-center; if I hadn't realized that, I'd have probably missed a corner or two (I know the track so well my steering inputs are basically programmed) before adjusting. I was also able to quickly assess that this was the only damage to the car (aside from the obvious fender work), and keep driving hard to maintain 3rd place.
BTW, sorry I came off as such a di*k, It was a bad day, I turned into a pompous know it all somehow, but I'm trying to avoid that in the future. Half of the alignments I've done were on Porsches, I obviously don't know it all.
...no worries, some days are like that...
I'm impressed. Wish I was that good at Mea Culpa
