Yokohama A048 1st Track Day Review (my 993 - cross post from 993 forum)
Old 07-01-2006, 12:02 AM
ceboyd
ceboyd's Avatar
Default Yokohama A048 1st Track Day Review (my 993 - cross post from 993 forum)
Many here were curious about what I thought about the A048 so I wanted to post here as well:
So today was 88 degrees and sunny and my first experience with the A048s!
They started out brand new (NOT heat cycled and I have never shaved a tire and don't even know if these are optioned to be shaved anyway)...
So far I'm very pleased with them!
What I immediately liked:
It started out 66 degrees this morning... only my 1st lap was 'new mold greasy' (granted I did drive 80 miles to get to the track) but by my 2nd lap I already got a really decent laptime and then got consistant 1:24s all day long at Blackhawk farms. (Now I used to get consistant 1:23s all day long with my DSSRs BUT I also had my 100 cell sport cats and ECU reprogrammed by Steve which are now both gone) so I'm pretty pleased! My record laptime was 1:22 at blackhawk farms but again that was when I had the 100cell sport cats, ECU retuned and DSSRs and of course a different day... different track conditions, etc.
Anyway, what I really like about these tires is:
- no need to wait for them to warm up -- they stick right away! (ahem - not the case with MPSC)
- They 'talk to you' and are very consistant/predictable
- They are available in proper 993 sizes and not odd sized like the Toyo RA1s
- They are readily available from TireRack (where I prefer to order since South Bend, IN is NOT that far from Chicago which makes for cheaper ship costs)
- They have deep cut tread meaning they can be driven to/from the track in rain without extreme worry like with RA1s after just 3 track days. (Eric has already put 3 track days on his A048s and the tread is still very much there unlike his RA1s sitting removed with 2 ever-so-slight lines visible now -- aka no rain day tire now and may as well be a hoosier the way they look without tread)
- They cost less than RA1s and less than MPSC
What I don't like about these tires so far:
- They are very noisy in the street... noisier than DSSRs, MPSC or Toyo RA1s (....so I turned up the tunes on my kenwood HU/Sirius SAT radio and problem solved)
- I don't know yet how many days they will last compared to other's like MPSC, DSSR or RA1 (...not necessarily a negative but an unknown at this point)
- They aren't as cheap as the DSSRs were. (then again, nothing else is)
Old 07-24-2006, 01:23 AM
ceboyd
ceboyd's Avatar
Default 3 more track days!
so 3 days at Mid-Ohio and I'm LOVING these A048s
I have so much predictability. I'm at a point now where I like them MORE than the DSSRs
...oh, and the long drive from Chicago to Mid-Ohio (including a monsoon-type downpour with ZERO visibility) yielded no white knuckle driving due to tires (just white knuckle due to visibility issues)... so mission accomplished... an R compound tire good in rain driving to/from the track..
Nice thing to add was that they are the best WET track tire I've ever used other than normal street tires (but again, I have never tried the mighty Hoosier Rain tire either)
Old 07-24-2006, 02:45 PM
DGaunt
DGaunt's Avatar
my first set of 048s last year seemed to need a couple of laps to warm up or they could bite you unlike the previous 032rs.
maybe mine were early production orsomething, but i forgot about it once and wet 4 off at turn 5 @ T. Tremblant, with my student in the car! VERY embarrasing but no harm.
Other than that I love them for all the reasons listed above.
Old 07-24-2006, 03:40 PM
ceboyd
ceboyd's Avatar
well, what I did notice was that they did still need some time to get the air pressure up to perform properly... so no matter what I take it easy a bit that 1st lap... but they are NOTHING like the MPSCs when it comes to warm up need...
Old 07-31-2006, 08:01 PM
ceboyd
ceboyd's Avatar
o.k. another day at Blackhawk.. and all is still well with these tires!
so far I have 6 DE days on them and no worries of being close to cording YET!!!!
...still plenty sticky too!
Old 09-01-2006, 03:48 PM
ceboyd
ceboyd's Avatar
I got 2 more days at Blackhawk on these (so 8 days total) and yesterday inspected them to find I actually have more wear in the middle than on the sides (so I gotta go even lower than 28 pounds hot apparently)
I'll be at Road America for 2 days with them and expect them to be done after that (but that means 10 days total which I'm very happy with overall!)
This is the first set of R compounds I will have had that did NOT wear out prematurely on the edges (corners) so it leads me to believe that the 993 really works well with the A048 medium-hard compound (at least in the midwest)
Old 09-01-2006, 05:40 PM
earlyapex
earlyapex's Avatar
Thanks for the updates. I've got some decisions to make about tires for next year.
Old 09-01-2006, 06:18 PM
SundayDriver
Lifetime Rennlist Member
SundayDriver's Avatar
This sounds great. However, do not be so quick to assume that higher center wear means overinflation with low profile tires. Sometimes a low pressure causes the tire to run in sort of a double S shape and extra middle wear can happen with underinflation. 28 hot sounds pretty low for these tires. If you can get to a pyro, you could measure 5 places across the tire and see what pressure gets you a good pattern.
Old 09-01-2006, 06:23 PM
ceboyd
ceboyd's Avatar
Thumbs up
o.k. interesting observation.. I was going by 'feel' and rollover wear (or lack of it) thinking I had too much air... AND I had heard from a few others that these like very low HOT pressures for whatever reason...
I'll see if someone else at the track has a pyro I can borrow one session to check in the hot pits....
Old 09-01-2006, 07:12 PM
JJayB
JJayB's Avatar
ceboyd
Nice write up. Can you share how much camber your running? Thanks
Jimmy
Old 09-01-2006, 10:27 PM
Terry L
Terry L's Avatar
The A048 is the stock tire for the Lotus Elise with sport pack. I ran them last year. I could not avoid wearing them out in the centers - the same deal with A032s. 28 lbs hot is about right. The tires begin to slide a lot when the stick disappears and the change is pretty sudden. Badly worn A048s on a wet track provide one of the scariest experiences you will ever have.
Old 09-02-2006, 01:06 PM
ceboyd
ceboyd's Avatar
Originally Posted by JJayB
ceboyd
Jimmy
sure, I have -2.85 in front and -2.55 in the rear
Old 09-02-2006, 01:07 PM
ceboyd
ceboyd's Avatar
thanks for that insight.. good to know on the 'stick' wear out factor... I'll have to watch out for that then!
Quick Reply: Yokohama A048 1st Track Day Review (my 993 - cross post from 993 forum)
