Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Performance & Competition Discussion Areas > Racing & Drivers Education Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 10-06-2008, 06:25 PM   #1
997gt3north
997gt3north's Avatar
wallstreetoneil
Send a message via AIM to 997gt3north
Default uneven left vs right rear brake pad wear
- figured this was the forum to ask the question on
- my car 997gt3 with ceramics but running the motorsport green pads
- the stock pads were wearing very fast so i decided to try the greens (went through 5 sets of the stocks)
- the greens definitely last longer (much longer) but i noticed something with these greens that didn't happen with the stock pads (maybe because they went so fast, maybe it was because i was running a bunch of different tracks, maybe i'm trail braking more as i get faster, maybe the Paul Guard 50/80 LSD is causing it)
the issue
- the left rear pads were much more worn than the right rears
- i have done a bunch of days (almost all at Mosport in Toronto)
- Mosport is a clockwise track
- can anyone explain why the left side rear pads would wear more than the right side?
- i have some guesses but i would like some feedback from the track pros
thanks
paul
To remove this ad, register today or login if you already are registered!
997gt3north is offline   Reply With Quote
Old 10-06-2008, 07:03 PM   #2
RonCT
Moderator
RonCT's Avatar
Traction Control on or off?
RonCT is offline   Reply With Quote
Old 10-06-2008, 09:24 PM   #3
997gt3north
wallstreetoneil
Quote:
always off
Old 10-06-2008, 11:17 PM   #4
todinlaw
todinlaw's Avatar
When you say much more, are we talking about like 20 to 30% more? i I have never seen a left right differential. Thinking trail braking and turning left would cause more load on the outside left but I don't think that can explain it. check the location and condition of the pad retaining spring on the left. if it was not centered it could cause some excessive wear, otherwise I am clueless.
Frank
PCA Nationally Trained Instructor # 200907140
Mid-Ohio Region PCA- Track Events Chair
Member:TnT Racing
1999 Spec Miata # 35
NASA Great Lakes Region
SCCA Ohio Valley Region
todinlaw is offline   Reply With Quote
Old 10-07-2008, 12:11 PM   #5
997gt3north
wallstreetoneil
Quote:
- this is the first time i've seen this
- left rear pads maybe 2mms left
- right rear pads 6mm left
- fronts as usually more like 8 to 10mm
- the Motorsport Greens come about 2-3mm thicker than the stock ceramic pads which have about 10mm of material when new
- i check if the pistons on both rears and everything appears to be working
- what i'm left with is thinking that it must be trail braking on a clockwise track (left side wheels turning and braking more than the right side) and when i added my Paul Guard 50/80 LSD it has allowed the car to be even more stable under braking and thus i must be using even more trail braking
- if this isn't it then i must have left the tc button a few times and missed it
Paid Advertisement
Tags
brake, car, control, left, outer, pad, pads, rear, side, traction, uneven, unevenly, wear, wearing, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright ę 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
