Anyone running ITBs on a NA 996?
so your current ones will work for a 3.4L 996. do you have airboxes like those on a gt3 RSR?
Jake this sounds very interesting. Would you indulge us with a picture or too. Also what effective improvement do you see in adding one of these to your boxster engines.
As for improvements, well these are only designed for performance enhanced engines that feature internal mods that boost reliability AND Performance and are not capable of being effectively tuned with the stock plenum/ industion arrangement. Applying these to an otherwise stock engine, or an engine that has only bolt on enhancements would generally result in less drive-ability and and RPM range that would only be effective on the track.
We have used these on smaller Boxster engines with the omission of vario cam and our solid lifter modification that allows for much higher safe RPM and for that application they really shine. Engines like this are maintenance intense and can't be owned by those who lack mechanical skills.
Also, isn't the intake plenum arrangement interchangeable between the 2.7, 3.2 and 3.4? I may likely have this wrong but I seem to recall a conversation during a boxster to 3.4 engine swap and the potential reuse of the 2.7s intake plenum due to clearance issues in the boxster engine bay withe the 3.4 motor.
Thanks and always, awesome work. I love that you will potentially be our source for hop ups like the Type IV world has enjoyed for years
we already are that source and have been working on this for the past 3.5 years behind closed doors. I have approached this engine with the same intensity and dedication as the Type 4 and we have already gotten results that are beyond comprehension by most.
Jake, any thoughts on becoming a Rennlist Sponsor? You're getting good pub here.
I'd be open to chatting with the admin here about the detailos associated with being a Sponsor of the site.
