Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Performance & Competition Discussion Areas > Racing & Drivers Education Forum
Old 10-06-2009, 01:38 PM   #16
TR6
TR6's Avatar
Surge brakes are probably fine for a light open car trailer. But for anything heavy like an enclosed trailer or a heavy open steel trailer with tire rack, loaded tool box, etc, I would recommend electric brakes. Using a good electric brake controller (I use a Prodigy), you have the ability to "tune" the amount of braking force and also how early it starts to engage based on the weight of your trailer and how the trailer is "behaving". You can actually adjust it for an unloaded trailer vs. a fully loaded trailer (think horse trailers, car trailers, etc). You can adjust it for winding mountain roads vs. flat highway. You can even fine tune the braking preload for high winds. You cannot make those kind of adjustments with surge brakes.
Surge brakes also don't have as reliable of a provision for an emergency disconnect switch to engage the brakes if the trailer unexpectedly becomes disconnected from the tow vehicle. Yes, some surge brakes have the little cable lanyard to pull the lever if the connection becomes loose, but that assumes the trailer is still close enough to the tow vehicle to have wire lanyard connected. I had a boat trailer come loose from my truck once (don't ask) and the weight of the trailer literally snapped the emergency brake cable lanyard which meant I had no emergency braking on the trailer.
Electric brakes are used on large/heavy trailers (think RV's, etc). Surge brakes in my opinion are better suited for lighter trailers and are a compromise for ease of use (no electrical controller or connection required on the tow vehicle). If surge brakes were really better than electric brakes, they would be used on heavy travel trailers, big horse trailers, etc (10,000 lbs and up). But they aren't. Those trailers use electric brakes.
Just my 2 cents from someone who is admittedly NOT a trailer expert.
Greg H.
1993 Porsche RS America
2002 Spec Miata
1999 BMW Z3M Coupe
1976 Triumph TR6
TR6 is offline   Reply With Quote
Old 10-06-2009, 04:06 PM   #17
Martin S.
Rennlister Extraordinaire
Martin S.'s Avatar
Smile
Quote:
Originally Posted by John H View Post
just don't try to back up a hill.
Now why didn't I think of that!!!!
Martin
Treasurer: Porsche Owners Club
A quote attributed to Greg Brown from Precision Motor Werks, Anaheim, CA sums it up well, "What part of Porsche Racing did you think is going to be cheap, is it the the Porsche part, or is it the Racing part?"
Martin S. is offline   Reply With Quote
Old 10-06-2009, 04:27 PM   #18
John H
John H's Avatar
I couldn't back up this driveway with the car on the trailer....
John H.
HWFM Racing Team "Visionary"
1995 Porsche 993 track car (again)
2006 GMC HD3500 Crew Cab Diesel Dually
2002 Boxster S
1999 Porsche Boxster (one day to be a SpecBoxster?)
John H is offline   Reply With Quote
Old 10-06-2009, 04:29 PM   #19
CornerCarver
Send a message via AIM to CornerCarver
Are you serious? That's a big problem for me. Thank you! You just saved me big time.
Al
Past rides:
02 996 X Koni
95 993 C2
97 E36 M3
95 993 C4
95 E36 M3
90 E30 M3
LocoDeMoto.com
CornerCarver is offline   Reply With Quote
Old 10-06-2009, 04:35 PM   #20
007DT
007DT's Avatar
Don't know about trailex; but the boat trailer(s) I've had all have a switch/pin that allowed for backing up an incline without issue. In fact most have either a switch or are not as sensitive to low speed incline such as when backing -up.. At least that has been my experience.
Dave______________________
04 GT3 Track ready,
08 Escalade
04 T-Reg w/ 21" BBS
GONE
95 C2 Black on Black
02' Koni Car
007DT is offline   Reply With Quote
Old 10-06-2009, 04:43 PM   #21
TR6
TR6's Avatar
Yeah, surge brakes should have a lock-out lever or pin that you lock when you want to back up without engaging the brakes. However, it is kind of a PITA to have to get out and set the lock-out pin everytime you want to back up. Another drawback of surge brakes...
Greg H.
2002 Spec Miata
1999 BMW Z3M Coupe
1976 Triumph TR6
Old 10-06-2009, 04:49 PM   #22
ltc
Super Moderator
(training wheels attached)
ltc's Avatar
Quote:
As mentioned, just make sure there is a pin/lever that allows you to disable the surge brakes when backing up....and that it's in good shape and working.
Ask when the last time the brake fluid was flushed/changed, the brakes inspected and the axle bearings checked.
Check the tires for signs of sidewall cracking (sometimes an issue in very cold climates over time), make sure the spare is present and functioning.
Also make sure you have the correct size socket for the lugs on the trailer wheels.
You'll start to develop a checklist for the trailer just like a checklist for the track car.
...Lewis
ltc is offline   Reply With Quote
Old 10-06-2009, 04:53 PM   #23
aj986s
aj986s's Avatar
FWIW, my Trailex has never had any problems backing up a hill. When I installed a new surge unit, I saw how it has a small but stiff shock absorber that apparently deters engangement of the brakes until a certain threshold is exceeded. If the trailer is locking its brakes on a driveway incline as gentle as the one above, I suspect the shock may be shot. Easily replaced.
Granted a very steep hill or stabbing the throttle while backing up a hill might cause the surge brakes to engage. I guess that depends on the steepness of the terrain around you.....
Tony P.
'89 944S2
'84 944 SP2 Racer
'85.5 944 (my son's bribe...)
'00 Boxster S (wife's DD)
...and other assorted vehicles as needed.
aj986s is offline   Reply With Quote
Old 10-06-2009, 05:09 PM   #24
John H
John H's Avatar
In all fairness, my surge brake trailer was a 1999 Texas roll back (really cool and actually got more looks at the track than the car on it). I have no idea what other manufacturers have to stop the surge brakes from locking up when backing. I assumed the trailer I had was a "higher end" unit. Pretty comical to watch me the first time IA tried to back in there though. Lots of black marks on the pavement.
John H.
2002 Boxster S
Old 10-06-2009, 05:33 PM   #25
MUSSBERGER
MUSSBERGER's Avatar
Quote:
It should have free backing hubs.
1981SC black metallic,no sunroof, departed.(bonehead move)
2004 Cayenne, base, departed.
2005 987S Boxster, guards red, Stuttgart built, departed.
1978 SC E track car.
2005 997 black, pollen magnet.
Allied products..........
1998 540i
1983 380SL 50k Jewel (Mom's from Cali)
2006 Titan
2005 Wrangler
MUSSBERGER is offline   Reply With Quote
Old 10-06-2009, 06:31 PM   #26
rlm328
rlm328's Avatar
One of the reasons that surge brakes are popular with boats is that you are always putting them in water so you so not have to worry about the electrical connection. The nice thing about the electric brakes is that they are adjustable, they also have an emergency feature that in the case the tow vehicle and the trailer become seperated they will engage. The electric brakes are enertial so the harder you apply your brakes the harder the trailer brakes will engage. Just a precaution as you mentioned you had a light tow vehicle.
Bob
87 951: 2.8L Stroker, Turbonetics T3/T4, Vitesse MAF, Siemens 72 lb Injectors, Tial 46 mm Wastegate, MBC, SFR Stage 1 Headers, Lindsey 3" Exhaust, AC and Heater Delete, Autopower Full Roll Cage, JIC Coil Overs, Weltmiester sway bars front and back, and to stop it all 996 monoblocks
06 Cayman S
rlm328 is offline   Reply With Quote
Old 10-06-2009, 06:42 PM   #27
mglobe
The Penguin King
mglobe's Avatar
I don't know enough to debate the relative merits of the two braking systems, but TR6's comments make a lot of sense.
That said, I want to add to the comments here that I have a Trailex with surge brakes, and I've never had a problem backing it up. That includes backing up my driveway, which is relatively steep, while the trailer was loaded with my 996 and two full sets of wheels.
Mike
TWS Chief Martini Maker and Keeper of banned substances.
2006 997S
2000 996 -- 996 Spec Racer is on the track
Want to read about the 996 Spec concept? http://www.996specracing.com/
Quote:
Originally Posted by Bull View Post
It is just my natural tendency to give people the benefit of the doubt and go easy on them I guess.
mglobe is offline   Reply With Quote
Old 10-06-2009, 06:53 PM   #28
jpinkert
jpinkert's Avatar
Same here...there's something in the mechanism that allows you to back up freely. Never had an issue even on an incline.
'81 911 SC Euro - PCA E Stock
'72 911T
jpinkert is offline   Reply With Quote
Old 10-06-2009, 07:30 PM   #29
rlm328
rlm328's Avatar
You can back a trailer up that side walk you call a driveway?
Bob
06 Cayman S
Old 10-06-2009, 08:10 PM   #30
lawjdc
lawjdc's Avatar
Quote:
Originally Posted by jpinkert View Post
Mine has surge brakes and I'm mostly happy with them. As others have said, they always work and self adjust. But if you're going over any big mountain passes and have a long downhill, you might prefer to have electric brakes that you can manually adjust. A long steep downhill could apply the brakes...
Actually this is a very good point. If your towing route includes a downhill stretch, your brakes will quickly wear out, and there is not much you can do about it, other than to fit an additional set of brakes to the second axle to balance the wear on the other axle.
2007 GT3
Past Porsches:
1973 911T/S, 1984 Carrera Targa, 1987 Carrera Cabrio, 2005 Carrera S
lawjdc is offline   Reply With Quote
Tags
aluminum, backing, brakes, car, ct80210, fix, hooking, sale, surge, trailer, trailers, trailex, unit, video, work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
