Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Performance & Competition Discussion Areas > Racing & Drivers Education Forum
Old 10-27-2009, 11:51 AM   #16
onefastviking
User
onefastviking's Avatar
When you took tire temps where were they ?
Quote:
Originally Posted by trackjunky View Post
I have two R888's that will fit the rear from my first purchase. I'm gonna throw these on with maybe .5 degrees less camber and see what happens.
You know, this may have been some of the reason my car was a little loose.....too much camber for the R888's. The fronts, BTW look perfect.
onefastviking is offline   Reply With Quote
Old 10-27-2009, 08:13 PM   #17
TRT41
TRT41's Avatar
This may have already been covered, but I thought I'd throw this out there.
Just finished a track weekend and I saw similar wear patterns on the rear of mine and three other 996's and 911's. That is, the inside half of the rear wears out twice as fast as the outside half.
I run more camber than the other cars I saw, but the result is basically the same: bald to corded inside half of rear tires while outside half still has grooves left.
Anyone else seeing this with the R888's.
(BTW rear camber -2.6 toe -3mm's)
Bill - thanks for starting this thread. I can't find my alignment numbers and it will be next week before I get it to the shop to get them and then reset for less camber. I'll post ASAP.
996 Black coupe-slower than it looks, now a 996 Spec build
996 White cab-faster than it looks
That's some catch, that Catch-22.
my black 2002 interior parts are for sale, check this link>>
http://forums.rennlist.com/rennforum...ferrerid=59068
TRT41 is offline   Reply With Quote
Old 10-27-2009, 08:34 PM   #18
AudiOn19s
AudiOn19s's Avatar
I ran -2.7, then -2.4 in the rear of my 996 with R888's. I think -2.2 would have been about right. This is with a 900lb rear spring.
Andy
AudiOn19s is offline   Reply With Quote
Old 10-27-2009, 11:04 PM   #19
trackjunky
trackjunky's Avatar
Quote:
Andy
Andy, I'm heading in the exact same direction. What are you doing with front camber?
Bill Sisco
HWFMR's Official Non-Member
2008 Touareg V8 - luxury car hauler
1999 996 C2 (GTB/996Spec in the making Ohlins, GT3 Sway Bars; Racers Edge Upper Shock Mounts; GT3 Rear Toe Links; GT3 Bumper; Getty Spec Wing; Still going)Wrap by Visual Promotions www.visualpromotions.net set-up by www.rennsportporscheworks.com
1986 951 PCA F Racecar - SOLD
1984 Euro Spec 3.2 Carrera - Sold
trackjunky is offline   Reply With Quote
Old 10-27-2009, 11:07 PM   #20
lawjdc
lawjdc's Avatar
you do know that you can swap the rears on R888's, side to side, to double the wear, right?
2007 GT3
Past Porsches:
1973 911T/S, 1984 Carrera Targa, 1987 Carrera Cabrio, 2005 Carrera S
lawjdc is offline   Reply With Quote
Old 10-28-2009, 09:40 AM   #21
AudiOn19s
AudiOn19s's Avatar
I was down to -2.7 front (from -3.1) and it was about right. I think I could have still backed off a bit but it wasn't far off. Sold the car so I suppose I'll never know.
Andy
Old 10-28-2009, 10:20 AM   #22
997gt3north
User
997gt3north's Avatar
Send a message via AIM to 997gt3north
- on my 997gt3 (305/30/19) -2.2 in the rear was about correct - guessing that -2.0 would have been perfect
- on the front (235/35/19) i was at -2.7 (my guess is that -2.3 would would have been perfect)
997gt3north is offline   Reply With Quote
Old 11-11-2009, 11:14 AM   #23
TRT41
TRT41's Avatar
Bill- getting back on the R888 alignment issue, my before and after numbers. I am seeing even tire wear across front and rears, running 38/39 hot pressure. before/after numbers:
front/left front/ right rear/left rear/right
camber -2.27/ -2.37 -2.40/-2.33 -2.06/-1.58 -2.19/-1.53
The before numbers worked great for Nitto NT-01 225/275 front/rear and MPSC 225/295. 2002 996 C2, driven to an from track.
Old 11-11-2009, 08:13 PM   #24
J richard
J richard's Avatar
....looks like the spec series bailout is causing some ripples...$150 rebate on 205/15 888s...
J Richard
93RSAstreet/93RSAracecar/944SPEC #19
02bmwX5 4.4 tow+race support/06bmw330 sport
...your results may vary...contents may have settled...
J richard is offline   Reply With Quote
Tags
2001, 2002, 996, carrera, cycling, heat, inside, miata, porsche, proxes, r888, rear, tire, tires, turbo, wear, wearing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
