Thinking about racing NASA events.......
#166
Boston DMD
I like the Nasa format with a typical day being practice, qualify and sprint race, both days. If I want an enduro there are usually a couple 3-hour ones throughout the season. It's not sprits one day and enduro the next. My personal experience has shown the Nasa drivers to be very competitive. GTS is wide open so the potential to start an arms race exists, but at the same time you do not have to spend a fortune on your motor since it is Wt/HP rather than potential Wt/HP. The average cost of a GTS car has risen consistently, but we drive Porsche's.
I have also found the guy driving the beater Honda is as concerned about his car as I am about mine. Most guys are on small budgets and trying to get the most enjoyment out of what they can afford. I have not noticed a difference in number of incidences at Nasa events versus other bodies.
Nasa Mid Atlantic, Great Lakes and Midwest all have very strong, growing groups. Not uncommon to have 25-40 cars, sometimes with their own run group. I would suggest you give it a try and see if it's for you.
#167
Thanks - I was aware of the Yoko as well. Haven't done much racing since they started it and I still have a couple of sets of sticker hoosiers.
Since hoosier does contingency in Time Trial as well I was thinking of running hoosiers for TT and Yoks in the race group :-) - we usually have 7 or 8 TT cars in my class.
I may look into running both at BW weekend after next as there's always 6 or 7 cars in TTS....
#168
Ya - we usually have a "super size" option for TT so if you are already racing you can add TT for $100 for the weekend....
#169
No that's not what I'm saying. I'm merely pointing out that the potential limitations of the hp/wt stucture in NASA don't really come up with a bunch of guys running the two series. The one instance where it does come up is a prepared car running against a stock car NASA.
Paolo, disillusioned yet? ;-)
Busting your chops Sean I hope you get that. What i am getting at is that Paolo won't find refuge in NASA - your post supports this point. Heck even in spec miatas there are good cars and then great cars...
#170
NASA Racer
I think we're saying opposite things, but honestly I can't tell for sure. What I'm saying is the hp/wt is the dominant variable in the equation and far outweighs any other car development such as brakes, aero, gearing etc in this specific example of dual racers in PCA and NASA and is a better approach to classification of cars.
#171
#172
#173
However once you get past that the last 2-3 seconds (for longer tracks, 1-2 seconds for shorter track) will be determined by all the things you mentioned. Races are won and lost by less margin that that per lap. This where GTS can turn in a chassis based arms race.
#174
That is true to first approximation.
#175
NASA Racer
My point is it won't happen if you're running stock in PCA and NASA GTS. Yes, you might get beat by someone who is running fully developed for NASA GTS only but we're talking specifically about a bunch of us running D and E stock in PCA who won't be making those those kinds of changes to run in NASA. It's the same guys and seeing where we all stack up on HP/WT will be a better approach than what we've got right now in PCA.
#177
I don't know........
They might bump you up in prepared class with the fear that on the straights you will quickly pull away from your stock class competitors.......
BTW, this is my 5000 post, so I am done posting for a while.........
#179
Actually, you have more than 5000 posts when you include your posts under....oh, never mind!
#180
However being competitive in GTS is really hit or miss. Even if you are at the top of the power/weight.
However NASA is not just about GTS. NASA has other classes to. Personally I would never run GTS since I can't put a budget limit on the class. I can see spend spending spending trying to be competitive in GTS1 or GTS2 even.
If I did not run in 944 spec (or another spec class) I would still run in NASA, but do so in Performance Touring. The rules appear complex, but smart building can make fast car on a budget inside the rules.
My 944 spec as it stands is not competitive in Performacne Touring, but given that it is built to the 944 spec rule set it make sense that it also not optimized for Performance Touring. The good news however is in performance touring I can probably run my 944 in 4-5 classes depending on how I chose to mod the car. Stock is one cars. Ligthened is another. Turbo swap is still another. 3.0 968 motor with super light weight is yet another.
