Spec Boxster build cost?
Old 07-12-2010, 03:14 AM
Greg Smith
Greg Smith's Avatar
Default Spec Boxster build cost?
Does anyone have a price sheet for the expected parts cost to build a Spec Boxster(DIY)? Also, what wear items should be replaced and what's their cost? Thinking of building a Spec Boxster, but trying to see if it's financially feasible first.
Thanks,
Greg.
Old 07-12-2010, 11:16 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,490 Likes on 2,272 Posts
you need to be a LOT more specific.
what shape is your car in?
you plan to win?
you doing work yourself?
you care about how the car looks.
anywhere from $10k to $35k
jupeman, dell, and i have/had very nice builds and is at the $$$ scale of things.
i have also seen some home jobs that are just as fast. so all depends on how handy you are, what you want and how much time you have. my car took 3 weeks to do from day one to race ready. so i paid to have it done quickly as well.
Old 07-12-2010, 11:23 AM
Gary R.
Gary R.'s Avatar
If just bolting on all the mod parts allowed to a solid car, the parts alone (including a good welded in cage) will run between 15K and 20K depending on your cage builder. I posted a pretty complete list last year compiled from the Brad Robert's site and other sources. The labor to install all these parts is substantial.
Old 07-12-2010, 12:01 PM
himself
himself's Avatar
Greg,
Here is one that I found a few years ago when I was contemplating. I am almost certain that it is a build sheet from someone here on Rennlist, but I didn't retain that info. I have the actual .xls file if you want it (PM me).
-td
Name:  Spec Boxster Build Costs.jpg
Old 07-12-2010, 12:53 PM
jrgordonsenior
jrgordonsenior's Avatar
There are several SB's for sale right now at prices that are substantially discounted from their build costs. One is only asking $25k for a good car!...
Old 07-12-2010, 02:17 PM
Gary R.
Gary R.'s Avatar
Where are they advertised?
Old 07-12-2010, 02:29 PM
utkinpol
utkinpol's Avatar
what do you think about 996 gt3 instead of a boxster? that is quite a different car and imho way more fun. i think i saw some in low $40K a month ago.
it`s just easier to start with a proper GT3 than to try to push stock boxster to gt3 level suspension wise, etc.
Old 07-12-2010, 02:52 PM
Greg Smith
Greg Smith's Avatar
Thanks to everyone who has responded so far. I don't have a boxster yet, so condition is unknown. Yes I plan to win. All of the work will be done myself, except for possibly the cage. I'm mainly just looking for part prices to save some time.
As sick as it sounds, I'd rather build than buy... yes I know.
996 GT3 is a fast DE car, spec boxster is a race car, so there's really no comparison. I'm only looking for a race car, I've already won my DE championship.
Thanks,
Greg.
EDIT-Gary R., I searched your posts for "boxster" and couldn't find the list, any tips of what word it might be under? Was it on RL or the now closed down spec boxster forum?
Old 07-12-2010, 03:10 PM
ZSA Motorsport
Former Vendor
ZSA Motorsport's Avatar
It cost me a good chunk more to have my Spec boxster built up. I love the dang thing like nobody's business. fun, pretty dang fast, and dialed in.
i just wanted something super nice and highly competitive.
when you start with stuff like data acquisition or fire bottle systems, and suspension, you can rack it up pretty quickly.
Mine was built by Rick Deman. i asked him to pop in here and give his few cents. i think he even has an F class and E class build ready to roll.
Good luck and enjoy!>...
Old 07-12-2010, 04:20 PM
Gary R.
Gary R.'s Avatar
I'm the same way, but I will do 99% of all the work myself. If I was paying labor I wouldn't build.
Absolutely, Apples and Oranges
One spot I found it was on Pelican. The list was derived from a combination of sources, the main one being the "Kit" Brad Roberts sold for about $14K. I added to that, will bring it up closer to $20K..
Full cage
IMS bearing/carrier upgrade from LN Engineering
Kirkey Road race seat
PSS9's or 10's
Swift Springs (450/500)
4 Wheel bearings
Tarett 986/996 rear toe links (legal starting Jan/2010
Stainless braided brake lines
4 NEW Zimmerman cross drilled or solid rotors
Screw in Grand Am approved studs with bullet nose
GT3 front anti roll bar w/drop links
4Way adjustable Tarett rear bar with drop links
4 GT3 Control Arms, 4 pivot points and an assortment of shims
Complete 3rd radiator package w/hoses/clamps/nut plates/bolts + two bottles of Water Wetter
Complete lightweight flywheel and clutch package (two special tools included)
Complete Mechanical Accusump Kit w/lines/adapters and mounting hardware
Latest Porsche Motor Sports Air/Oil Separator (keep your good current one as a spare)
986 Fuel filter (change it, write the date on it with a Sharpie)
Two oil filters
Two cases Mobil 1 15W50
X51 Oil pan with magnetic drain plug
Underdrive Pulley/Power Pulley
BoxsterS/996 larger oil cooler with O-rings (easy bolt on)
CaymanS engine mount
Wevo tranny mounts
Direct bolt on custom exhaust with silencer
GT3 style retractable tow hooks (pair) direct bolt on with factory hardware
Lightest Spec hard top available
MOMO steering wheel/quick release and adapter
Shift risers 997 Shifter (they did away with a lot of the plastic)
Scroth seat belts (Hans compatible 6 point pull up lap belts and pull down shoulder belts)
Electrical cutoff switch kit with all wiring needed for two buttons
Floor plate for just below pedals (comes with grip tape)
Electrical Fire Suppression System with 6 Nozzle capability
http://forums.pelicanparts.com/boxst...mpleted-2.html
Rick DeMan
Basic Sponsor
Rick DeMan's Avatar
Whoa..!! Hold on there young fellas..!!
First, lets clarify just what a "spec" Boxster is before we get way to far into discussing the costs as they varry significantly...
First, a true "Spec" Boxster is built on the 97-99 2.5L Boxster that can be had for 5-12K depending and then they are built using very specific parts designated by "spec" box rules...
When it comes to PCA spec F class cars we start with a 2003-04 Boxster S that run from 18-25K then they are built with a parts list that is far greater than a "spec" car including things like factory hardtop, Moton shocks and a whole host of other parts...
A true spec car, built the way I would do it would cost between $40-50K complete...
I would say look at some of the ones for sale, but look very carefully, not all spec cars are built the same...and they are only as good as the base car was and the person who put it together...
Good luck..!!
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
Porsche Sales & Service
Porsche Race services and parts
www.DeManMotorsport.com
Old 07-12-2010, 10:14 PM
TIM COSTA
TIM COSTA's Avatar
Rick,
Coming from someone who paid much less than your quoated price for their car, Im wondering what the heck comes in a $50K Spec Boxster??
Thanks,
Tim
Old 07-12-2010, 10:22 PM
jdistefa
jdistefa's Avatar
Tim,
Rick is building a PCA class F car, not a "Spec" Boxster per NASA/POC/PCA rules.
Old 07-12-2010, 10:25 PM
TIM COSTA
TIM COSTA's Avatar
Default HERE
http://www.nasaforums.com/viewtopic.php?f=31&t=35768
Old 07-12-2010, 10:26 PM
Werkstatt
Former Vendor
Werkstatt's Avatar
Here's one, but i'll sell it for $43,000.
What's it come with, I'll show you Timmy!
Quick Reply: Spec Boxster build cost?
