Winter Trailer Storage
This is my first winter for storing my Featherlite Trailer and I wanted to get an idea what steps are recommened. It will basically not move from End of October (past) until April of next year.
Stored in a parking lot with some cover from the winter elements. Should I add air to the tires and cover the Plug that gets connected to the car.
What are the typical items.
Rodney,
I'm a few miles from you. Can you pass me some info on your find (location, price, etc)? I was calling the marina in Norwalk about spots. Speedsport - Danbury had a location for $175/month.
thanks
thanks
Don't forget the battery which may control brakes,etc.If you can't keep on a tender,take it out and bring it inside.I also keep a roof vent cracked to equalize temps in/out of the trailer.
tom B.
tom B.
try and get direct AM sun on the roof. pitch the trailer to let the snow melt run off. This will keep the snow/ice load down. Not pretty when the roof is deflected . Check it after a heavy wet snow and rake off the edges. If you get a wopper or store in the shade Cut some 2x4 and make plywood end caps to brace the roof. Or do what most people do and do nothing. (in the spring just cauke those peskey roof leaks)
Regards
Tom
Regards
Tom
I am lucky where I don't have to worry about direct snow. Also, don't have to worry temp equalization because the area is open. The trailer is basically covered in a parking garage, but snow could blow in from the wind.
Good suggestions. I will shield the tires from UV exposure. No option to keep the battery on a tener, but I will look into disconnecting it any storing it in my garage at home. Time to visit the trailer this weeking for some housekeeping
