Running r comp tires backwards
Old 04-28-2011, 08:01 PM
tasracer
tasracer's Avatar
Default Running r comp tires backwards
got pirelli p zero corsa asymetricos on the 965 and the lefts r wearing more than the rights (only track at mid Ohio)
Can I safely run em backwards? Just flip the right rims over to the left and vice versa... Running the tread pattern backward
I assume it's no issue
Old 04-28-2011, 08:22 PM
racer
racer's Avatar
Hmm.. they are called "asymetricos" which would imply a "no" answer.
First is the tread pattern issue. Second could be internal construction issues.
There are other "r" comps that can be run in either direction whose only issue might be reduced effectiveness in the wet, should a tread be showing.
Old 04-28-2011, 08:23 PM
Jim Child
Jim Child's Avatar
It's only an issue if you're running on a wet track.
Old 04-28-2011, 09:03 PM
bobt993
bobt993's Avatar
I completely agree with Jim.
Old 04-28-2011, 09:06 PM
J richard
J richard's Avatar
I find the RPM limitations a bit of a problem when running in reverse...
but the only reason a tire is asymetric is due to the tread pattern, shaved or dry you'll be fine...
Old 04-28-2011, 11:40 PM
Z-man
Z-man's Avatar
+1.
And after 6-7 track days, the tread won't be too much of an issue no matter how you run the tires.
I would also suggest flipping them on the rims after about 1/2 their life.
-Z-man.
Old 04-28-2011, 11:42 PM
Gary R.
Gary R.'s Avatar
I run mine sideways every other race....
Old 04-29-2011, 01:08 AM
altonj
altonj's Avatar
Gary,
You suffering a little stress lately??
Old 04-29-2011, 08:05 AM
Gary R.
Gary R.'s Avatar
Originally Posted by altonj
Gary,
C'mon, it was a little funny no?
Old 04-29-2011, 08:11 AM
bobt993
bobt993's Avatar
Gary, your scrubbing too much speed that way.
Old 04-29-2011, 08:24 AM
wanna911
wanna911's Avatar
Turn em, run em.
Old 04-29-2011, 08:30 AM
CWhaley
CWhaley's Avatar
Just stay away from the wet spots
Old 04-29-2011, 10:34 AM
VaSteve
VaSteve's Avatar
I run my tires backwards, but I'm usually both feet in.
Old 04-29-2011, 10:40 AM
CWhaley
CWhaley's Avatar
it is alway nice to see the track from the opposite direction.
Old 04-29-2011, 12:34 PM
Z-man
Z-man's Avatar
If you drive FLATOUT, it doesn't matter which way the treads (or your car for that matter), are pointing.
-Z
Quick Reply: Running r comp tires backwards
