Question for IQ3 users - sensor setup
Mr. Excitement
USM plugs into the V net via a standard V net cable and gives 4 analog inputs. It has 2 voltages available for each of the 4 inputs and you can run both 5 V and 12 V devices. I have one Vnet cable that runs from the IQ3 to a USM and then daisy chained a second USM right after. 8 input ports. I have brake pressure, oil pressure, oil temp, and TP that is taken from the stock 993 TPS. The second USM is used to monitor the espresso maker.
- the VNet module, which attaches the sensor to the VNet can bus
- the sensor only, which wires up to the USM. Its the USM that connects all four of the sensors it takes with the VNet can bus.
Its a lower cost solution because the USM provides a single VNEt connection rather than each sensor having its own.
Didn't see Kurt's post........he explained it better, I suspect.
Peter, I think Racepak's analytics software might be called DatalinkII
Basic Site Sponsor
Basic Site Sponsor
Received 2,888 Likes
Oops. Thanks for the correction. Is there video integration in the software to insert it in the data window real-time or is TrackVision a better solution?
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
This link contains the answer I believe:
http://www.trackvision.net/DatalinkII.shtml
It would appear that DatalinkII will import the video file so you can see the data and the video together. Though you need to manually sync the video with the data. DatalinkII is integrated with TrackVision so creating a video with data is simple. It appears to be quite a nice setup.
Scott
Mr. Excitement
Hey Sean. No, Racepak's sensors come in two flavors:
There are non race pack sensors that work well with the USM if you want to save a $ or two. The savings is offset by time spent programing the IQ3 to see and accept the values from the sensor. The USM has 0 to 5V and 0 to 12V that can be used on / off or 0 to full value. The software lets you set what each end of full swing is and has pull down menues with many sensors and trimming resistors already programed in. Tony K made it look easy when he dialed in my setup.
