****WARNING*** Early 944 Spindles
I thought I'd post this warning after I broke a spindle and lost a wheel in the Hairpin at Sebring. The early 944s up to 85.5 and all the 924S models use a driver's side spindle with a hole for the speedometer cable. They are weak, and when constantly used in racing will fail. I am posting this because I knew of this problem and ignored it. The result was the loss of the wheel, hub, spindle, brakes and fender on that corner of the car. I "tri-cycled" it off the track safely, but had it broken in a high speed corner, it could have been a lot worse. Here are some pictures of the failed part, showing how little metal there is. I have since upgraded to 87 spindles and Hubs, which are not only stronger, but use larger wheel bearings. I maintained the rest of my early offset suspension, modifying the strut mounts slightly, where they bolt to the spindles. I recommend going directly to the late spindles, because they are larger and hopefully stronger than the "hole-less" 85.5 to 86 spindles.
John,
I have witnessed this failure twice. Both on low speed areas of the track--thank God.
In my opinion, the PCA should require documentation in the drivers race log book that a upgrade has been preformed.
Glad to hear everything turned out OK for you--minus the financial hit.
Jim
Jim
You can't see the crack. I have a spindle that showed a crack with dye penetrant that looks great under normal visual inspection.
https://www.pegasusautoracing.com/pr...asp?RecID=1207
plus you need a UV light
https://www.pegasusautoracing.com/pr...asp?RecID=6752
You can test the spindles while mounted, so a rotor change is the perfect time to test them.
it sounds as if its easier just to upgrade. I know there have been some failures of the 85.5 - 86 spindles. has anyone had an 87 or later spindle fail?
I received this reply on the same posting on the 44Cup website:
"Thanks for sharing this.
I broke my driver side spindle this summer at the Tremblant track (Qc, Canada) and discoverd a new meaning to the word understeer!
Actually, my car is a 85 1/2, so my spindle did not have that hole but it broke just the same.
Anybody has a set of late spindles for sale?"
All spindles are subject to breaking, not just the early 944NA's. The late offset 944NA thru 944S2 and 968 has a larger barrel, but given the heavier cars and increase in HP they are still subject to issues.
I have mine cleaned and magnafluxed each time I do brakes. It's a $50 job at the local machine shop.
Check you hubs too.........
I have a set of late offset spindles hubs and rotors for sale.
The brake cooling ducts and backing plates are not included. Everything has low hours from a spec car that was converted to a Chumpcar
Right. I had one fail too. Part was 25-28 years old and had 8 years of racing on it. I replaced with another hollow one. Looking at the frature surfaces it is clear it had been cracked for a long time before it failed.
