Recommendations for data logger/predictive timer/video overlay systems?
Thanks VR for the promo.
I'm asking $1300 for my Racekeeper system and its brand new (NIB). Includes OBDll.
My new ride (see avatar) came with loads of electronics so I don't need the Racekeeper.
Somebody buy this thing. I'll pay the shipping in the US.
Tom B.
Tom B.
^^^ this is a very good deal ^^^
The Solo DL offer everything the standard Solo does plus multi data inputs via CAN or OBDII port and Smarty Cam use? Does AIM offer a plug-n-play harness for the CAN inputs that would fit my 2010 GT3 RS 3.8L 997.2? I'm not one for cutting up OEM wire harness. I am already assuming the OBDII cable is plug-n-play. Do I get the same data via CAN or OBDII?
Thanks -Troy
I've done a bit of searching and I found that ReplayXD will make a version of its camera for RACEPAK. One that will be link through the V-Net and that will trigger automatically, just at the same time the data triggers in the IQ3 dash. And I assume that it will also route some power to it. Making it more like chase cam set up, but at an affordable price. The only thing is that there will be 2 memory cards to unload...
I sent an inquiry to replay to have an idea when it comes out. That should be a very nice addition to the IQ3. I will test it whenever its ready.
c.
c.
data is not same for CAN and ODBII connections. look at post 198 here
https://rennlist.com/forums/racing-a...-399-a-14.html
on the left is ODB2 screenshot, on the right is CAN.
only real issue with ODB2 connection is that it does not supply any brake pedal data. CAN bus supplies brake switch data as 0 or 1 but there is no brake pressure. there is a workaround to use negative G force as indicator for braking. if you do not want to cut any wires ODB2 will work fine most likely.
I'm going the Traqdash route here shortly (I already have the data input connector). However the Gopro addon for the Traqmate is way to pricey. Just wait till the new Wifi "bacpac" for the Gopro becomes available shortly, you can turn on the camera with a wireless button for around ~$50ish dollars, while adding new features. I plan on velcroing the "switch" to the dash.
http://gopro.com/hd-hero-accessories...-remote-combo/
