DE @ TWS on Feb 04-05 Anybody
I just signed up for the LSR DE @ TWS on Feb 04 and 05. After my DE in Nov i am looking forward to this one and wondering if anybody on this forum is also planning to go.
I ran my spyder stock with SS brake lines for the last DE, planning to try track pads for this one. All else will be stock. Changed my brake fluid before the last DE in Nov, should i do the same before this one too?
-Preetham
-Preetham
tech used to ask for a 6 month brake fluid change, which is fine for street driven cars, unless you've been doing a lot of tracking since Nov., do your tech check off sheet. the most common ommission is brake pad wear. most of the usual suspect will be attendiing. see you there
The Penguin King
I doubt you'll need to change your fluid, but it wouldn't hurt to do a quick bleed.
I'll be there, hopefully with Green-17 working this time.
I'll be there.
It's easy.
The Penguin King
The Penguin King
BTW, we had over 100 people registered in the first 20 minutes after registration opened, and sold out completely in two days. Our initial signup on cr.net set a new record for the site, surpassing the rate at which registrations came in for Rennsport Reunion.
Ill be there. I signed up at 12:02, hit the registration button and there were ~75 names already
The Penguin King
-jd
Thanks! Ken mentioned that there were 61 registrations in the first minute. I look forward to meeting 'y'all'. Did I use that right?
