986 Coolshirts
Old 06-20-2012, 03:06 PM
KaiB
KaiB's Avatar
Default 986 Coolshirts
Has anyone else had delivery problems with these folks; in particular with the shirts FR or normal ones?
Old 06-20-2012, 03:22 PM
Polarporsche
Polarporsche's Avatar
Yes, the Shirts from 986 are on back order, mine is suppose to arrive near the end of June, I was told this after I order the system.
I called SpeedMerchants and they had some in stock, it was delivered to me the day after I placed my phone order. I didn't want to wait for the back order so now I have two shirts, pricey system compared to cool shirt IMHO.
http://www.speedmerchants.com/collec...-shirt-systems
Old 06-20-2012, 04:40 PM
Nizer
Nizer's Avatar
Received 1,742 Likes on 921 Posts
Still no Nomex or CarbonX versions available yet, correct?
Old 06-20-2012, 05:30 PM
Phokaioglaukos
Phokaioglaukos's Avatar
I've thought the 986 shirt would be superior to Cool Shirt because it has a greaer area of cold water in contact with the torso, but they also claim superiority becase: •One large chamber contains the cooling coils that are packed in ice •The other (smaller) chamber is the water reservoir •Water is cooled as it passes through the aluminum cooling tubes.
Why is that an advantage? It seems that it just add another layer of heat exchange to the system that would reduce efficiency.
Old 06-20-2012, 05:32 PM
winders
winders's Avatar
The best setup is supposed to be a Cool Shirt cooler hooked up to a 986 shirt....
Scott
Old 06-20-2012, 06:06 PM
Tom W
Tom W's Avatar
I replaced the pump of my FAST cool system with one that pumps twice as much and also got rid of the intermittent switch so it pumps constantly. It keeps me plenty cool (was ok, now is great). I use that standard shirt in carbonX or cotton.
Old 06-20-2012, 06:10 PM
mglobe
The Penguin King
mglobe's Avatar
It makes the ice last longer... at the expense of reduced cooling.
Old 06-20-2012, 06:53 PM
TraqGear
Basic Sponsor
TraqGear's Avatar
Great system, but the shirt will melt in a fire...not optimal.
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
Old 06-20-2012, 08:56 PM
early_grayce
early_grayce's Avatar
I wear it under a 4-layer Nomex suit... shouldn't be a problem.
Old 06-20-2012, 09:01 PM
jakermc
jakermc's Avatar
Nearly certain Performance SpeedTech located at MSR has them in stock:
http://www.performancespeedtech.com/
Old 06-21-2012, 08:08 AM
Nizer
Nizer's Avatar
Originally Posted by early_grayce
I wear it under your a 4-layer Nomex suit... shouldn't be a problem.
Had this discussion with Pat Long at an event. He was pretty adamant that you should never wear anything under your suit except Nomex.
Old 06-21-2012, 09:27 AM
Phokaioglaukos
No advantage there! Just a patented sales point. The shirt does look nice, though.
Old 06-21-2012, 11:04 AM
fuenfer
fuenfer's Avatar
That raises a question - what about the rubber tubing that's part of the shirt (NOMEX or otherwise). Wouldn't that melting cause some serious issues as well?
Old 06-21-2012, 12:57 PM
KaiB
KaiB's Avatar
Just recieved a reply. The shirts are now delayed until July/August.
FWIW, I'm impresed with the system (despite the fact that I've had to use a FAST shirt with it). The unit is solid and the variable speed control precise and very easy to adjust from cool to really cool.
Old 06-21-2012, 01:12 PM
TraqGear
Basic Sponsor
TraqGear's Avatar
That's where a good FR shirt comes in...should offer some protection from the tubing as long as the tubing is on top of it. Also, the tubing does have cool water in it which will delay melting as well. BTW, none of this stuff is fire PROOF, just fire retardant that will allow time to get out of the flame unhurt. Even nomex will burn. The big difference is that FR materials shouldn't catch fire and keep burning, like cotton. They will also be more resistant to flame and heat. With that said, I would much rather wear cotton as an under layer than something that would melt to my body like underarmour.
Quick Reply: 986 Coolshirts
