Rumble vids!
#31
Doug,
Please feel free to critique my videos posted earlier. My 2 cents: I think you are significantly faster than #87. However, you are turning very similar lap times. This may be because there are several turns where you are giving away time by either turning in early or not hitting the apex. Specifically turns 3 (NASCAR) and T11A (Oaktree). If you turn in a little earlier for NASCAR, you can get on the power a little earlier and be full-throttle by apex. More importantly, I think you are turning in at Oaktree too early. Take a look at my video and you will see what I think is a better line. You are doing a good job of getting onto the left curb before turn in, but by turning in early and more gently, you are not able to get to full throttle until later. What shows this the most is #87 pulling away from you as you are tracking out. If you turn in a few feet later, turn in harder to get the car rotated, and get to full throtte by apex, you will get a better launch.
You are definitely faster than him up the esses, through roller coaster, and through hogpen. Do you have any idea why he was braking between 16 and 17?
I really hope this unsolicited advice does not offend you. If it does, I aplogize and will remove it.
Don
Don
#32
Doug actually got the coveted "Workers' Choice" award for his drive in the enduro. Well deserved too!
#33
i think at the 2:50 mark the rear end got a bit loose and thats why it put me toward the right side there. 75 + minutes of racing plus 90+ degree air temps = slippery!
#34
Doug,
Don
Don
no offense whatsoever! any and all critique/ constructive crticism is welcome. It's the only way to get better.
Not sure why he was braking in those spots. I need to get back to VIR and try working on your suggestions. I agree that I was poor in NASCAR turn, it bothered me all weekend.
#36
Don,
#40
Rock on Doug!
#43
Easiest pass I ever made (not that it did me any good inthe long run). Not sure why the moroon and silver 911 suddenly went left and drove Streak off the track. Can only assume that the Green 911 slowed very quickly and left it nowhere to go. Streak, brilliant job of staying straight and getting back on track. Great set of pictures.
#44
Perfect Angel
#45
