moving enclosed car trailer with tractor?
Old 12-23-2012, 02:59 AM
Traffic53
Traffic53's Avatar
Default moving enclosed car trailer with tractor?
anybody have any experience with using an old, modestly-sized farm tractor to move 8000-10,000# of car hauler around?
i was exploring the idea of buying an old Farmall to hook to the 24' enclosed in order to move the trailer around the property. my trailer stays at the track, but it would be nice to move the trailer to the paddock when i'm using the racecar.
i'd like to hook up a tractor and leave it. the question is then, will a basic tractor like a Farmall or an old John Deere take on a 1000# tongue weight and tow a 9000# box around the track property?
quite obviously, i know zero about tractors.
http://commons.wikimedia.org/wiki/Fi...e-Lanz_710.jpg
Old 12-23-2012, 03:18 AM
Darkstar1
Darkstar1's Avatar
Should not be a problem.
Old 12-23-2012, 08:05 AM
bgiere
bgiere's Avatar
I do it all the time...works great...easy to hitch up, easy to manuever.
Old 12-23-2012, 09:26 AM
Scootin159
Scootin159's Avatar
It's not as easy as it sounds - the first big concern would be braking if you have any hills to go down. Unless you've got a mamouth tractor, the trailer will just push that tractor around without the trailer brakes. You can probably figure out a way to wire up a simple trailer brake controller though.
The other issue you could run into is the tounge capacity - if you use the three point hitch you'll be able to do fun things like raise/lower the ball to make going over terrain easier. However many small tractors have a 3ph rated to only 750# or so.
Alternatively there's normally another hitch point up near the rear axle that can take a ton of weight, but it might really limit your maneuverability.
Old 12-23-2012, 09:29 AM
Scootin159
Scootin159's Avatar
Engine torque however will not be an issue - most tractors are limited more by traction than engine power.
Old 12-23-2012, 09:45 AM
pmason
pmason's Avatar
Assume you are using the 3 point, really this isn't much different than moving it with a truck, but will have a shorter wheel base and tighter turning radius. I have moved my trailer (24ft) with a hitch clamp on the loader, while more maneuverable but you are limited on tongue weight.
Old 12-23-2012, 01:02 PM
Traffic53
Traffic53's Avatar
ok, good to know. i think the tractors i'm considering, like the Deere in the link, have nearly a ton of lifting capacity on the rear 3-point. so i guess that should pretty much handle the tongue of a 9000# trailer, if i understand it correctly?
as for brakes, that's a good point. i certainly don't need the trailer driving the tractor. that said, it's pretty flat on the track property. i just need the tractor to be able to stop and control the trailer in the kindest environment. there won't be a speed element, or any on-road considerations. all slow speed. hopefully the brakes on-board the tractor can handle this?
another one...this machine will sit outside. are tractors pretty stout as far as firing up after sitting outside for 2 or 3 weeks at a time, or do they need to be babied?
Old 12-23-2012, 01:08 PM
Scootin159
Scootin159's Avatar
They're almost made for that. Had a tractor that I used for nothing more than mowing some unused fields - so it only got started about 3 times a year, and never needed anything more than maybe a jump start the first start after winter.
Old 12-23-2012, 02:12 PM
pmason
pmason's Avatar
Sorry I didn't see the tractor picture the first time, that should be fine hooking up to the 3pt. I have a Case/IH DX33 (compact 4x4) and would have no problem moving with the 3pt. When I move it with the loader I need to make sure I have enough weight on the back.
Old 12-23-2012, 02:28 PM
paver
paver's Avatar
It will probably have a low range gear that will be geared so low that it will pull the trailer with the engine at idle speed. I have a 1989 Kubota that gets run about three hrs a year. It starts every time and runs like a sewing machine. It is amazing.
Old 12-23-2012, 03:42 PM
bgiere
bgiere's Avatar
...Good points...I assumed you were talking about an Ag tractor, not a compact lawn/garden variety tractor...Something in the 50-75 HP range would have the weight, brakes, hydraulics, etc to handle that trailer...I should have clarified.
Old 12-23-2012, 04:51 PM
Traffic53
Traffic53's Avatar
yep, i'm thinking small Ag tractor.
ok, great news. i'm liking this idea more and more.
thank you for the replies.
Old 12-23-2012, 05:06 PM
pontifex4
pontifex4's Avatar
You'll find other uses for the tractor quickly.
Old 12-23-2012, 06:19 PM
Doc GTO
Doc GTO's Avatar
Our Deere 950 will start even after an EMP attack!!! LOL.
Old 12-23-2012, 06:50 PM
J richard
J richard's Avatar
Or:
http://youtu.be/ybV0coKggbU
Quick Reply: moving enclosed car trailer with tractor?
