Are 5 point G-force harnesses made in May 2004 useable for DE?
Rennlist Hoonigan
which cost no drachmas
Becuase SFI/FIA say they are only good for a certain amount of time and the auto manufacturer doesn't say anything about how long they are good for. Thank you lawyers.
I get that it is the rating bodies. And with the belts in race cars subjected to more UV because of no windows, and more exposure to the elements, I can get it. Just seems like the lawyers are killing fun.
SO if I put the three point on over the 6 point I'll be safe again...
There is a reason they started making 6 point belts. Look at where the lower belt goes and then look up "testicular rupture"...
Time to chuck them...
Actually some regions do. I remember watching a very embarrassed instructor running around VIR trying to find a new set when they actually did check the date on his harness.
But yeah the age allowance on 3 point is weird.
The San Diego PCA club checks the dates on harnesses and will not allow you to run a DE with expired ones. I believe they even check for autocrosses and they won't let anyone wear a 3 pt with an expired 5 or 6 pt.
PCA Carolina's Region tech is a stickler on outdated belts too for DE. I don't believe the belt manufacturers recommend running both your stock seatbelt and a 5- or 6-point belt at the same time. Use one or the other.
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: info@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist on your next order or mention Rennlist during your phone order.
Visit us on Facebook
ApexPerformance.net
Every PCA and NASA region I have instructed with checks the dates on harnesses. Some will let you use an SFI rated harness for 5 years from date of manufacture.
The current G-Force FIA rated harness is very reasonably priced and good for 5 years.
http://www.ogracing.com/g-force-fia-...ck-harness-set
Kind regards,
Kind regards,
