My Trailer Diary
Old 02-12-2013, 06:02 PM
  #106
KaiB
KaiB's Avatar
Originally Posted by 24Chromium
What ever tires TPD supplies. I'll have to research it and get back to you on that.
Please have a discussion with them after researching tires here.
Despite the fact you may be hauling a somewhat "lighter" load, keep in mind the fact that you will be hauling at 75mph during the hot summer.
"Good enough" does not cut it with trailer tires. Get two spares mounted up and attached to your trailer also.
KaiB is offline
Old 02-12-2013, 06:03 PM
  #107
24Chromium
24Chromium's Avatar
My double axle 24' uses 15" tires.
24Chromium is offline
Old 02-12-2013, 06:20 PM
  #108
KaiB
KaiB's Avatar
You need to KNOW what load range ST tires they will be supplying and the psi rating for the wheels they want to send with them. Tire make rand would be a help also.
After all this, please do the most important thing right...
KaiB is offline
Old 02-12-2013, 06:40 PM
  #109
Sboxin
Sboxin's Avatar
Originally Posted by pontifex4
Interesting. And they will mount and run normally on regular light truck wheels?
Yes, 6 lug trailer or truck wheels - my friend went to 16" wheels because
he said they don't make a 15" tire in this model
- Bridgestone Duravis M700 ( I think...)
- E Rated 80PSI
Regards,
Sboxin is offline
Old 02-12-2013, 08:47 PM
  #110
24Chromium
24Chromium's Avatar
The tires on my new TPD will be Good Year Marathon ST225/75R15 Load Range D.
Old 02-13-2013, 12:12 AM
  #111
zip465
zip465's Avatar
I was recently told that I should consider Load Range E tires, still looking into what needs to change. Currently using Marathon ST225/75R15 Load Range D on my 20' TPD. I'm calling Justin at TPD to find out more
zip465 is offline
Old 02-13-2013, 12:36 AM
  #112
mooty
GT3 player par excellence
mooty's Avatar
Received 5,482 Likes on 2,269 Posts
tow at 75mph in ca, you will NEVER get to track. speed limit 55. if you do 65, ok, more than that, you get pulled over.
std 15" is the ubiquitous good year marathon, or you can be like me run G series ;-)
mooty is offline
Old 02-13-2013, 06:21 AM
  #113
KOAN
KOAN's Avatar
Marathon tires are pretty poor. I use E rated Maxxis. I change them every 3-4 years to be safe and have 2 spares. 24 ft ace @ 10k lbs.
KOAN is offline
Old 02-15-2013, 12:21 PM
  #114
24Chromium
24Chromium's Avatar
Things Start To Get Real
Two of my friends recently took delivery of their custom-built TPD trailers. It's been awesome to follow their progress as they've been sharing photos of their builds along the way. Well, yesterday things finally started to get real for me. TPD informed me that my official completion date is March 15th. They haven't yet sent any photos of the trailer itself in progress, bust they did send me a photo of the Catalina aluminum gas cylinder topped off with the Smith regulator.
Name:  Alum Cylinder 2-14-13.jpg
My build is kind of unique in that I'm having TPD source very nearly the entire contents of the trailer. From the Honda EU3000 is generator to the Mac's tie-down straps and everything in between. I'll just need to arrive at TPDs facility with the truck and the race car, load up and continue north on I-5 to Thunderhill!
To date, they've received everything with the exception of:
Arrow Components 24" door cabinet
Arrow Components 18" strap hangers
Pit Pal tire gauge holder
Kennedy 6 drawer cabinet
These few remaining items are all on-order and due to arrive within the next 2 weeks. Needless to say, the anticipation is killing me!
Old 02-15-2013, 08:58 PM
  #115
24Chromium
24Chromium's Avatar
I went to visit the "bowling alley" today - i.e.: the new Mooty/Garcias trailer. Chasen was kind enough to smile for the camera...
Old 02-15-2013, 09:07 PM
  #116
24Chromium
24Chromium's Avatar
It IS Real
Shawn at TPD must be reading Rennlist! LOL
Here are the first photos from the shop of my trailer coming to life...
Name:  Kerila 24 cut chassis parts.jpg
Name:  Kerila 24 cut parts.jpg
Old 02-15-2013, 09:10 PM
  #117
24Chromium
24Chromium's Avatar
Here is another shot of the "bowling alley"...
Name:  purple sun copy.jpg
I think it needs some graphics!
Old 02-15-2013, 11:22 PM
  #118
chasen1211
chasen1211's Avatar
Attachment 703682
Hahaha yes it is quite the blank canvas.
chasen1211 is offline
Old 02-18-2013, 01:55 PM
  #119
24Chromium
24Chromium's Avatar
Floor Jack Hanger Brackets
I have an old floor jack, dating back to when I started tracking in the late nineties. It's a lightweight aluminum racing jack. I believe it's a clone of the Brunnhoelzl jack.
At any rate, it has served me well and is still going strong. I designed a set of custom brackets to hang it off a wall inside the trailer. I got the idea from a fellow trackrat...
Name:  Well Worn TPD copy.jpg
Here is my interpretation of his effort. You can see that I added my own twist...
Like the original, the jack is hung from a hook on the upper bracket, the hook catching the front wheel of the jack. The bottom bracket is simply there to keep the rear wheels from bashing the trailer wall.
Both brackets have small flanges to provide a place to secure the jack handle. The lower bracket also has a couple of holes in order to use a bungee strap to secure the jack tight against the wall.
Here are the actual parts, fresh from the fabricator. I've added some rubber grommets to keep the jack handle from rattling.
Name:  jack hanger brackets.JPG
Old 02-18-2013, 02:30 PM
  #120
24Chromium
24Chromium's Avatar
Another happy RL'er picking up his 38'er at TPD today...
Name:  Derek pick-up.jpg
Jeez... these guys are making me feel so inadequate. I've just got a TAG, not a manly gooseneck. And even worse, mine is a wimpy 24'er.
Quick Reply: My Trailer Diary
