Harness
Old 05-13-2013, 09:09 PM
911Königin
911Königin's Avatar
Default Harness
What kind do you have and why do you like/not like it?
Old 05-13-2013, 09:11 PM
GuyIncognito
GuyIncognito's Avatar
six point sparco. love it.
btw, I'm disappointed the thread title wasn't "fifty shades of harnesses" or something similarly provocative
Old 05-13-2013, 09:13 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,433 Likes on 767 Posts
Mine are made of sable.
Old 05-13-2013, 09:16 PM
911Königin
911Königin's Avatar
Will have to see what I can come up with!!
I wish mine were
Old 05-13-2013, 10:08 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Schroth Hybrid III HANS from here.
Comfy on the boys. Quality hardware. Easy to do up and undo. Stay put. Not cheap though.
Can't tell you how well they work in a crash (and hope to never have to test'em).
Marc
Old 05-13-2013, 10:29 PM
Matt Romanowski
Rennlist Hoonigan
which cost no drachmas
Matt Romanowski's Avatar
I have a set of 6 piont G Force. Work fine - easy to adjust, stay very tight. Easy to buckle. Half the price of some others.
Old 05-13-2013, 10:52 PM
Van
Van's Avatar
There are both nylon and polyester webbing... each has pros and cons. Ployester stretches less, but will break down faster in sunlight.
Old 05-14-2013, 08:39 AM
SiberianDVM
SiberianDVM's Avatar
6 point G-Force with cam lock quick release. And they are blue.
(G-Force also has a rebuild program for expired harnesses)
Old 05-14-2013, 08:49 AM
Veloce Raptor
For a serious answer, I just installed Sparco HANS-compatible 6 points in my car.
Old 05-14-2013, 08:53 AM
aj986s
aj986s's Avatar
I like the Schroth Profi ii 6-point belts. The "pull-down" option on the lap belts is the easiet to adjust lap belt I've ever used. In our LeMons car (multiple drivers) it has made our pit stops a lot easier.
Not certain which car you're considering for a harness, but remember its part of a larger "system". You'll need correct seat (with proper opening for shoulder and anti-sub belts, proper mounting points & hardware, and either a roll bar or proper harness bar, in order for it all work properly/safely for you. A rollbar or harness bar can nullify rear seat use. Then, you need to also consider a HANS type device to protect your neck better.
In terms of safety, a modern car's 3 point belt and air bags is probably just as safe for the driver. But with a harness, the dynamics are quite different. The airbag is taken out of the equation for the most part. The harness holds the body in the place; the HANS is what controls/protects the head's & neck's movement. An improperly installed harness can actually be quite dangerous in a real crash situation.
But....a harness does hold you in place much better during performance driving. I would defer moving to a harness "system" until your track performance gets the point where staying in the seat during cornering becomes an actual problem.
Old 05-14-2013, 11:04 AM
Coochas
Coochas's Avatar
I too was expecting something like "What type of strap ons do you use?"
Old 05-14-2013, 11:23 AM
mdrums
mdrums's Avatar
might be a good harness?
Old 05-14-2013, 11:24 AM
Coochas
Coochas's Avatar
Is that FIA?
Old 05-14-2013, 12:26 PM
911Königin
911Königin's Avatar
Sounds good
Do they come in any other color?
Another 6 point - anyone use 4 point?
I have already purchased the cage. I actually got jostled a lot more than I thought I would and am having a lot trouble with the seat belts.
I'll try not to disappoint next time
Comfy?
Old 05-14-2013, 12:30 PM
911Königin
911Königin's Avatar
Marc
I'm not too worried about the boys I asked if I could follow one of the instructors so I could see where the tires are hitting the apex and they put Tommy Burns in front of me.
Quick Reply: Harness
