Thoughts on the Necksgen Rev Head/Neck Restraint
#31
The 2 devices are similar it seems - limited protection- something is better than nothing. Our PCA regions gives a reimbursment towards purchase for Instructors. very nice.
#32
Basic Sponsor
They test for a 30 degree offset impact. Not very close to side for sure.
Basilar skull fracture with HANS has happened. V8 supercars (?) Ashley Cooper. The impact was that angular impact. I remember hearing of others but that one stands out. The video of it is pretty easy to find IIRC.
The apex of performance, comfort & safety since 2011.
All new racewear available now→ traqgear.com
#33
Basic Sponsor
You got that right. That's awesome on the reimbursement thing. Great to see regions getting more proactive.
#34
I just looked the crash up also- sad- Hard hit but at first glance you would not think fatal. We all have a hobby with inherent dangers. Life has an expiration date, Enjoy. - I'm a winner when I come home safe. I hope I never test my Necksgen Rev.
#35
Basic Sponsor
That's true. I have tested my Hans at Sebring unfortunately and it worked flawlessly. I've had neck surgery and have a metal plate in the past, but the wreck with the Hans didn't even make my neck sore.
#37
Ran 1st event with Necksgen Rev. Took 5 minutes to get use to restricted side to side movement. Awesome easy- Everyone was looking at it. A little tough backing out of parking spot. Much more comfortable - I'm so glad I got it instead of HANS.
#39
I've run a 1st generation NecksGen for 2 years now in a DE environment. As mentioned the side-to-side head movement restriction takes some getting used to, but I use the quick release mounts (supplied with unit) and it's easy for me to have the unit on and then connect it to my helmet while waiting in line to go on track. That way it's not restricting me in the paddoc while manuvering/backing. Once on track you'll never notice it's there. It's very comfortable and I've been nothing but happy with it.
#40
Cheaper than HANS offers more side impact and doesn't have the fixed angle issue that some HANS units have.
I'm guessing the new rev is even better but see no reason to spend the money again just to remove the yoke which doesn't bother me.
#41
Have you had this problem and is there a way to remedy this annoyance.?
Tom B.
#42
I've been wearing a defNder (predecessor to the NecksGen) since they first came out. I finally tested it with a HARD impact last September (see below, starting ~1:50). Notice that my impact was not directly frontal, but was significantly offset to the left. All four corners were torn off, hard enough to break two of the wheels. There is not much in the way of side-to-side restraint in my car, so the only thing attached to my head is the lateral tethers on the defNder.
I can't vouch for it in direct comparison to the HANS, but I can say that I'm very glad I was wearing the defNder. Without it, I might not be posting this.....
#43
Leatt makes one also and it is priced a little lower.
http://www.leatt.com/shop/braces/kart/mrx.html
#44
I've had my Necksgen for two years now and generally like it except.....like you, I attach it to my helmet while sitting in the car but for some reason my tethered male inserts slide to the rear making them difficult to locate and grasp especially with a halo seat.
Tom B.
Tom B.
#45
