Rear end sways under hard breaking
#31
Much better learning experience in a momentum car. Plus people usually invest too much $$$ in the car in comparison to what they spend on getting instruction/coaching.
#32
I have the same symptoms on my 2007 997 GT3 with 45,000 miles, it does have a LSD but I am told Porsche has the ramps/% split backwards... Can some one explain?
I would understand if the opinion is that Porche does no have the % at ideal, but to have them backwards... What went wrong? Why does the 997.1 and 997.2 both have this issue?
#33
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 3,798 Likes
#34
If stock internals on Porsche LSD they are pos brass which wear fast if u do quite a few trackdays. Lost mine at 11k. U can have it rebuilt with more durable internals like Guard Transmission. I think the 7.1 have the 28/60 whereas the 6.2 has a 40/60. U mite want to build with a 40/60 pack. Mike
#35
There is some sort of a "test" where one hub is held stationary and the other rotated and the torque required to rotate the other wheel is noted, or so I recall. This may be a hallucination on my part.
#36
Really not a true test unless u open it up but jack up one rear wheel and in neutral with no ebrake make sure u put a piece of wood in front of tire to prevent car from rolling. Try to manually turn jacked up wheel Clockwise or Counter Clockwise- should be difficult to rotate wheel if LSD is working. My stock oem LSD rotated either way easily. Put in a while new guard LSD it rotate say 3 inches then stops rotating. Mike
#37
LSDs in Porsches generally will offer more performance (i.e., lockup, biasing or whatever term you want to use) during braking than they will under acceleration. One often reads about 40/60 or 50/80 splits (let's not worry about what the numbers mean here).
Non-rear engine guys will often indicate that this is "backwards" or a "less than ideal %", but this works in our cars just fine.
Unless, of course, you're in a 935...
#38
1 Post
996FLT6, I think you should post on every page of this forum. Those pictures...............Ah....
Now back to your regularly scheduled program.
+1 on the LSD (had the same issue with my 996)
+1 on the dedicated track car other than a Porsche. Replace brakes on a Miata vs a P-car and you'll understand the long term value of not running a P-car on a budget.
#39
"Really not a true test unless u open it up but jack up one rear wheel and in neutral with no ebrake make sure u put a piece of wood in front of tire to prevent car from rolling. Try to manually turn jacked up wheel Clockwise or Counter Clockwise- should be difficult to rotate wheel if LSD is working. My stock oem LSD rotated either way easily. Put in a while new guard LSD it rotate say 3 inches then stops rotating." Mike describes the "test" I was thinking of. BTW, as I recall, extracting the LSD can be done without dropping the transmission...I think, could be wrong.
