No Helmet Drilling Allowed. What to Do?
Old 09-24-2015, 04:57 PM
MikeJim
MikeJim's Avatar
Default No Helmet Drilling Allowed. What to Do?
Pro racers are no longer allowed to drill holes in a helmet, so if this rule trickles down to club racing, and you have drilled into your helmet to attach a strap for a mic or earpiece wires, your helmet could suddenly be obsolete.
Thanks to Ron Zappendorf at Discovery Parts, there's now a cheap, quick fix.
Below is a typical Bell helmet with an earpiece receptacle attached with a plastic strap and rivet drilled into the helmet.
Next is the same earpiece receptacle attached with a 1x1" plastic adhesive-backed Mounting Base. Two zip ties securely hold the receptacle to the Base. No drilling. The mounting bases can be found at Home Depot in the electrical department (white or black). A 10-pack is $2.28.
Old 09-24-2015, 05:35 PM
chrisc
chrisc's Avatar
Thanks Mike!!! Just about ready to drill the holes for my new SRC radio set up. Now headed for The HD.
Old 09-24-2015, 06:03 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,496 Likes on 792 Posts
Just make sure you use a very high temperature adhesive if you are in a very warm climate.
Old 09-24-2015, 11:43 PM
J richard
J richard's Avatar
What about Hans posts? Only factory posts allowed now?
Quick Reply: No Helmet Drilling Allowed. What to Do?
