Full Scale Windtunnel Testing
This was the screen record of the 100mph step on the baseline run for a customer. Everything is measured at the 4 contact patches. There are as many steps as you want between 0 - 160MPH (240k). There's a print out of each step as well as a rolling graph and data record.
On the screen in the control room, you can see the previous 3 speed steps just below the current speed.
this output is particularly interesting because of how one side so different from the other. odd how that is even possible, unless the car was in yaw . But that would be interesting to know. (sorry , didnt mean to get too much off topic)
I would be nice to have time in the tunnel. kind of far away. in the mean time, im going to have to approach nasa ames to let me use theirs sometime.
The turntable the entire car sits on in the wind tunnel could be in yaw but the car is square on the measurement pads. I wasn't there for this particular test but if the front wheels are not perfectly straight you can induce a L-R variance. Small things can have have big effects with aero and sometimes big things have little effect. Anything will effect everything, you just can't know exactly how much until you measure it.
For anyone in the East, the UOIT wind tunnel is in Oshawa, Ont., 15 minutes from Mosport. If you're going to Mosport, an hour or two at the tunnel could pay off.
