Weight and Horsepower
I am sorry I tried to post something that I thought might be interesting or useful......clearly it was not either.
Yes. often talked about, often misunderstood as well.
The next chapter of this topic is the effects of the mass if added to the car's rolling parts.
wheels and tires or Flywheels. Once we get a transnational (linear, non rotational) equivilance, then we just plug it into your formula above to see the effects as if the equivalent weight has been put IN the car.
you often hear, relative to what you have heard about Hp to weight equivilance, is that "1lb rotating is worth 15hp" or something odd like that. (rotating mass to HP equiv) it's the same mistake.... with rotational it depends on how fast the load is being accelerated , or if its flywheels engine rotating mass, it depends on the gear you are in..... or , if it is on the wheel or tire after the rear end gear, it can only be an absolute maximum as if 2x that weight was in the car.
Then, there is actual HP/weight ratio vs Aero to HP ratios as well.
Edit:
an even easier way to do this is to just take the new HP/weight ration and take the 1/x (inverse) and then just multiply the weigiht savings to get the HP saved (or equiv gains).
2750 -100lbs = 2650lbs/225hp = 11.77 (hp/weight ratio) .849 is the inverse of that ratio ( 1/11.77) and then you just multiply that times the weight you reduced by , or in this case 100lbs = 8.49HP..... a little easier.
so, in otherwords... just take the new HP/weight ratio and take the inverse, and multiply it by the weight you have lost.
Edit:
WRONGLY ACCUSED!
Received 3,383 Likes
You guys are seriously messing with my diet! 10lbs equals 1HP because racecar.
All your fancy words, formulas and heavy thinking will never change this!
But for me, (and seems for you too) 10lbs for 1hp is a good ball park ratio and it works in most cases, except for Winders 2200lb 911.
2200lbs -100lbs is 2100lbs /300hp = 7:1 ..... (INV) x 10lbs = where 10lbs is more like 1.4hp, or in this case, 14hp per 100lbs
(lets check my work.... 2200lbs/314hp = 7:1...... same as above ratio but 14hp more for same HP/weight. )
didnt mean to add to give your diet unreasonable goals!
yep, and the short cut is just 8.63 (INV) x that weight.
.11587 x that weight = 11.59HP.... same result, just easier to think about and put in a calculator
My car weighs 2387 lbs with me in it (the car always has a driver) and it has about 265 HP at the wheels. So the power to mass ratio is 9.01:1.
If I removed 100 lbs, the power to mass ratio would be 8.63:1.
Removing 100 lbs from my race car would feel like adding this much HP:
(265*100)/(2387-100)=11.59 HP
Easier to think about? You have to calculate the new power to mass ratio, inverse it, and then multiply that number by the weight removed. That is not any easier to think about nor is it any simpler to input into the calculator than the formula I provided. The formulas I provided are simpler to deal with in a spreadsheet too.
I think so, but it depends on what you think is easier. For me, just thinking about new HP/weight ratio and 1/x that and multiply by the weight reduction is easy to think about as well.
Both ways are pretty easy
Thanks for posting... this comes up a lot!
