Your first time on slicks, what did you learn?
I'm sure this has been discussed before, but I went back as far as '09 and didn't see anything so I thought I'd start a new thread. Anyways, I'm scheduled for a lesson with my pro-coach for November 4th. It'll be my first time on Hoosier R7s in a 944/SP2 car. I realize these are DOT tires and not true slicks, but I gather they are pretty darn close to slicks in performance hence the question.
What were your biggest lessons that you remember from your first time on slicks? What advice would you offer?
Obviously I will not be alone, and I will listen to everything my coach says, but I'm just curious what others remember from their first time.
Thanks as always!
Thanks as always!
Basic Site Sponsor
Basic Site Sponsor
Received 2,874 Likes
Darn, Joe! I saw the thread title and thought "now, we're talking," in the belief that you were going to Pirelli DH's or REAL slicks, but instead, I find out it's R-Comps (which is the correct reference for what the R7's are). This is important because while some classes allow slicks (real, honest-to-God, not-for-highway-use-whatsoever), most allow R-Comps, or DOT graded tires that are designed solely for track use. If you said to someone that you ran "slicks" and they saw R7's/RR's/R1's on your car, they would be confused. So let's use the right terminology. These are "R-Compound" tires, not "slicks."
Same advice, though...
1) Buy NEW tires. Do NOT form opinions or tune the car on ANY tire, even scrubs, if you have ANY question about their age. Even BRAND NEW tires, if they are not from recent production, and especially if they'are not stored correctly, begin to degrade almost immediately, and you don't even need to run them for this to happen. Buy the freshest, most recent batch you can.
2) Get them nice and toasty before you lean on them (it was 29 degrees at the Skippy school at LRP a few days ago).
3) Best way to warm them up is to accelerate briskly in a lower gear and brake decisively fore and aft all the way around the out lap, maybe a lap and a half. Besides getting the brakes and you ready, the belts moving within the tire carcass generate heat from the inside out and distribute that heat throughout the tread surface more equally. Brings pressures up more quickly, too.
4) Have fun. The car will be much more competent with these than what you're used to. Incremental improvement is the watchword!
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
I echo what Peter says. And really pay attention to how much more communicative the car will be
R7 warm up slowly as peter said, but take care to do it progressively....if you lock up they do not take kindly..
Figure out your target pressure....start a little high in the morning and bleed the pressures down....use the same gauge all the time
Other thing I learned is a new way to describe the cost of something.......man that's a set of hoosiers....or I don't need thay cause thats a rear hoosier.
But, thank you as always for the sage advice!
I will be with Simon, and he already specifically mentioned that we were going to work on learning to "get heat in the tires" aside from just learning the new limits. Also, I read several older threads in which you guys discussed the importance of running on new tires so I think I have already learned that lesson. In fact one major reason I chose SP2 to start was so I could afford all the best every time I track or race the car. Meaning new tires, new brakes, and in general the best of everything allowed always.
So is the jump from R-comp to true slick worse than the jump from street to R-comp?
I have only ever driven on street tires. Mostly I have run Yoko NEOVA Advans, but I have also driven MPSC 2s, Potenza's, and Skippy's BF Goodrich.
Also: Be mindful of ambient temperatures. I don't run R7s at less than 40 deg F ambient temps and NEVER let them freeze. Plus, you will only be faster if you actually use the additional grip these tires provide for braking and cornering. R7s are useless in standing water - you will need rain tires too.
Basic Site Sponsor
Basic Site Sponsor
Nah, need to stay home, more...
No, not worse. Similar. Its all about building a new "belief system." What Frank said...
Plenty of people drive the same or slightly quicker speed going to R-Comps and to slicks, they just need to learn the "new" limits in a gradual, incremental way.
You're going to love 'em!
Higher grip, higher g-forces = faster breakaway. Also less communication when breaking loose than street tires. Outside of that, enjoy the grip!
I usually call them semi slicks or DOT slicks. Calling them r-compounds confuses too many people with MPSC, Trofeo, NT-01 etc. They are more than those but less than full slicks.
Higher grip, higher g-forces = faster breakaway. Also less communication when breaking loose than street tires. Outside of that, enjoy the grip! I usually call them semi slicks or DOT slicks. Calling them r-compounds confuses too many people with MPSC, Trofeo, NT-01 etc. They are more than those but less than full slicks.
R7 is a remarkably competent R-comp but as Evan mentioned you can flat spot one faster than... WHOOPS! Too late! Likely less of an issue in an SP2 car compared to a heavier higher HP machine.
Get heat in them and bleed them down. The slip angle sweet spot is real nice and consistent and they won't talk much sound compared to your streets.
The R7 sidewall must be stiffer than the old R6 which required car setup adjustments but once dialed in, the R7 is a fine R-comp IMHO.
Watch your fenders, too. The R7 squared shoulders tend to run wide so rubbing and cutting a brand new tire are real potential issues.
Have fun!
Have fun!
WRONGLY ACCUSED!
Received 3,336 Likes
I learned that I can blow money quicker on Hoosiers than I can at the craps table!
In truth, the one thing that I learned, especially being in the northeast, is how important it is to warm up the tires on a cold day - and even on a warm day as well. If you go out like a rocketship on your first lap on a summer day you will screw up your tires!
Basic Site Sponsor
Basic Site Sponsor
I've actually found the opposite to be true having gone back and forth between NT01s and PSS a few time recently. Once the PSS start squealing, that's all you are going to get out of them before they completely give way and both feet go in. NT01s seem to start slipping at somewhere near the same point, maybe a little faster, but you can really lean in to them as they have a whole more grip to give before they are going to give way. Just my experience though and I do believe that car setup has an impact on this.
