New mid engine RSR testing video
Old 11-01-2016, 07:19 AM
  #46
porsche993gtrsr
porsche993gtrsr's Avatar
isn't that for carter breathing/pressure relieve, don't know exactly how to call it. Like the BMW z4 GT3
Old 11-01-2016, 05:50 PM
  #47
fbroen
fbroen's Avatar
This bit:
Old 11-01-2016, 08:50 PM
  #48
bgiere
bgiere's Avatar
I'm betting it's a turbo motor
Old 11-01-2016, 09:58 PM
  #49
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,293 Likes on 1,463 Posts
Sounds like a turbo 6 and it does look to be mid-engined. Where can I buy one? A mid-engined 911, yummy.
Old 11-01-2016, 10:26 PM
  #50
Gary R.
Gary R.'s Avatar
At your Porsche dealer, it's called a GT4...
Old 11-01-2016, 10:27 PM
  #51
Carlo_Carrera
Unfortunately the GT4 doesn't have the good looks of a 911. If it did I would own one.
Old 11-02-2016, 08:43 AM
  #52
brake dust
brake dust's Avatar
Originally Posted by ir_fuel
How do you move the engine forward in a layout where engine and gearbox are directly bolted together, therefore also defining the point where the rear axles sit in the car? I would think that moving it forward will also move the diff forward? Or are they adding spacers or sth between engine and gear box?
This is a serious question. Just can't imagine how they would pull this off?
Engine has been moved in front of the tranny.
Old 11-07-2016, 09:22 PM
  #53
wanna911
wanna911's Avatar
A little birdy told me these cars were also at Road Atlanta recently and the times the were turning were double take "are you sure?" fast.
Old 11-08-2016, 05:30 PM
  #54
paradisenb
paradisenb's Avatar
Fast is not what matters. The BOP will remove that advantage. What a mid-engine platform can do is allow faster cornering speeds and better tire performance/longevity. Maybe they will get better mileage so they have less stops or quicker stops because of less consumption. I'm curious what else they are going to gain. What they should do is move the radiators so they don't get damaged from the least agro event. They have been a real weak spot in the 911 since going water cooled.
Old 11-08-2016, 05:48 PM
  #55
wanna911
wanna911's Avatar
You cant say fast doesnt matter and then say faster cornering speeds in the same sentence. Faster is faster. If its a faster car, all things equal, it has a better chance to win. BoP is going to decide who wins anyways, we know that already.
Old 11-08-2016, 06:58 PM
  #56
fleadh
fleadh's Avatar
Radiators in the RSR are very well protected, unlike the Cups.
-mike
Old 11-09-2016, 11:22 AM
  #57
z06801
z06801's Avatar
So is the consensus that the motor and trans are flipped?
Old 11-09-2016, 11:35 AM
  #58
paradisenb
paradisenb's Avatar
Sure you can. A 944 is a perfect example. The BOP is going to reduce RPM, HP and/or Torque to throttle the car's performance. Either way, that won't necessarily reduce cornering speed. Exit speed and top speed, however, could be effected for competition adjustments.
Old 11-09-2016, 12:34 PM
  #59
stownsen914
stownsen914's Avatar
It's more than just power adjustment though - there can be adjustments that affect handling too (and even beyond that). From the FIA/WEC site for GT cars:
• Minimum weight of the car
• Engine air restrictor and boost pressure ratio
• Fuel tank capacity
• Height of the rear wing
• Any other technical modifications
Old 11-09-2016, 03:33 PM
  #60
91K-Man
Registered User
91K-Man's Avatar
Gee, glad we did this a year ago. no 3 rads, 185f water temps. shroud is off which directs hot air to louvres in hood. room for 2 oil coolers, under headlights, 190 f. Plus more downforce.
Quick Reply: New mid engine RSR testing video
