New mid engine RSR testing video
Old 11-09-2016, 04:27 PM
  #61
wanna911
wanna911's Avatar
Originally Posted by paradisenb
Sure you can. A 944 is a perfect example. The BOP is going to reduce RPM, HP and/or Torque to throttle the car's performance. Either way, that won't necessarily reduce cornering speed. Exit speed and top speed, however, could be effected for competition adjustments.
It seems that you assumed I meant hp and top end speed only, while I think you know a faster lap is more than that. And winning endurance race even more than that. Weight, Aero components, etc do affect handling and the BOP controls those as well. If the car is faster, it's faster, and that matters. Period.
Old 11-09-2016, 05:50 PM
  #62
paradisenb
paradisenb's Avatar
True. But....If the car is 'fast' - relative to the other in class - they are going to take that away. My point is simply that they will need other advantages in the design to make the 911 competitive again. The current car can be 'fast' by air flow changes, aero, etc., but that car is disadvantaged in other ways do to rear engine design. The Ferrari and Ford GT are fast, but they benefit from mid-engine architecture. For example: all their tires may remain in the sweet spot later in the stint making them 'faster' over the entire stint. It is great that the car is fast and I hope it can return to winning consistently.
Old 11-11-2016, 05:56 PM
  #63
sl951
sl951's Avatar
Default Mid-engine 911? - new RSR
A new mid-engine 911 RSR?
Wow - that would fundamentally change the two core values of a 911 which is the flat 6 and rear engine layout.
Are we witnessing a paradigm shift!?
http://www.roadandtrack.com/motorspo...ectacular-911/
Old 11-11-2016, 05:58 PM
  #64
TRAKCAR
TRAKCAR's Avatar
Received 1,588 Likes on 736 Posts
Race cars and road cars are getting separated more and more.
Soon Porsche racecars will be completely irrelevant just like most brands are.
The last 911 "racecar for the road" was the 997.
  #65
sl951
sl951's Avatar
Old 11-12-2016, 01:11 AM
  #66
-eztrader-
-eztrader-'s Avatar
why doesn't every car (and woman) have hips like that
Old 11-12-2016, 05:33 AM
  #67
the-missile
the-missile's Avatar
991.1 was the beta tester for racecar development.
991.2 will be race engine derivated.
At least for the GT3s...
997 is not the last one
Old 11-12-2016, 05:37 AM
  #68
the-missile
if the engine is move forward by a very little and slightly upward, it is still rear engine and you have space for big aero...
Old 11-12-2016, 09:40 AM
  #69
brake dust
brake dust's Avatar
Engine and tranny will be flipped - engine in front.
Old 11-12-2016, 10:27 AM
  #70
MileHigh911
MileHigh911's Avatar
The Cayman has been the short wheelbase mid-engine beta tester for quite a while. Currently, wheelbase between 911 and Cayman are around an inch apart. All that empty space behind the front 2 seats will be filled with the engine, just like in the Cayman. I doubt they will do the same for the road 911 GT cars. This is a big fundamental shift. What if all future GT cars have no direct relation with the race car? Or, what if the only way to get a race derived, mid-engine with a 911 body was to buy a GT version? That would make them even more in demand!!!
Old 11-14-2016, 10:43 PM
  #71
NaroEscape
Basic Sponsor
NaroEscape's Avatar
Originally Posted by z06801
So is the consensus that the motor and trans are flipped?
A little birdie that works on them at Core says yes...
Bob Saville
Getting You On Track!
www.naroescapemotorsports.com
704-395-2975
  • Data Analysis & Coaching
  • Drivers Gear
  • Crew Gear
  • Car Gear
'07 SPC
'71 914/6 Huey
'04 GT3
Old 11-16-2016, 06:38 PM
  #72
Apex996
Apex996's Avatar
Not a turbo.
http://sportscar365.com/lemans/wec/w...hin-gte-rules/
"a normally aspirated engine gives us more freedom in the car concept, e.g. weight distribution.”
Old 11-16-2016, 06:44 PM
  #73
Sean F
NASA Racer
Sean F's Avatar
https://presse.porsche.de/prod/press...rsionid=683824
New 911 RSR for Le Mans
Stuttgart. Porsche will tackle the 2017 racing season with an all-out newly developed GT racer. The new 911 RSR makes full use of the breadth of the Le Mans 24 Hours GT regulations, and in addition to systematic lightweight design, features the ultra-modern, flat-six unit positioned in front of the rear axle. The four-litre, extremely light aggregate features direct fuel injection as well as a rigid valve drive and is characterised by outstanding efficiency. The new 911 RSR will make its debut at the Daytona 24-hour race in January 2017.
“While retaining the typical 911 design, this is the biggest evolution by now in the history of our top GT model,” says Head of Porsche Motorsport Dr Frank-Steffen Walliser. The new 911 RSR is a completely new development: the suspension, body structure, aerodynamic concept, engine and transmission have all been designed from scratch. The engine concept has enabled the designers to install a particularly large rear diffuser. Combined with a top-mounted rear wing adopted from the LMP1 race car, the 919 Hybrid, the level of downforce and the aerodynamic efficiency were significantly improved.
“For the 911 RSR, we deliberately focussed on a particularly modern and light normally-aspirated engine, as this gave our engineers immense latitude in developing the vehicle,” explains Dr Walliser. “Apart from that, in principle, the LM-GTE regulations stipulate the absolute equality of various drive concepts, as the torque characteristics of turbo and normally aspirated engines are aligned.” Depending on the size of the restrictor, the new normally-aspirated unit puts out around 375 kW (510 hp). Shift paddles on the steering wheel actuate the sequential six-speed gearbox with a magnesium housing, which delivers power to the 31-centimentre-wide rear wheels. The changeover to the new engine generation is now complete. After the 911 GT3 R and the 911 GT3 Cup, the spearhead of Porsche GT racing cars is now also powered by the same cutting-edge six-cylinder boxer engine family.
In the past, Porsche has already thoroughly pushed the limits with the concept of the 911 – in 1996 with the 911 GT1. With great success: In 1998 the 911 GT1 achieved the 16th overall victory for Porsche at the Le Mans 24-hour race. Back then, the fastest vehicle in the field emerged from the GT1 class.
For the first time, a Porsche GT race car features state-of-the-art assistance systems: the new 911 RSR is equipped with a radar-supported collision warning system, the so-called “Collision Avoid System”. Even in the dark, the faster LMP prototypes are detected early enough and misunderstandings can be avoided. A new safety cage concept and a new, rigidly-mounted racing seat enhance driver safety. With the seat fixed to the chassis, the pedalry can now been moved and adjusted to fit the driver.
The new 911 RSR’s serviceability has also been significantly improved: Entire elements of the carbon-fibre body can be exchanged completely in a very short time thanks to clever quick-release fasteners. Moreover, changes to the suspension setup can be performed much more quickly and easily.
With the look of the body wrapping, the 911 RSR is striking out in a new direction: For the first time, the GT racer bears the new factory design that has further developed the clear and dynamic design language of Porsche Motorsport. From a bird’s eye view, a hint of the Porsche emblem silhouette can be seen. The basic colours remain white, red and black.
In the 2017 season, the factory is expected to run the new 911 RSR at 19 outings which equates to more than 140 hours of racing. With two factory-entries, Porsche will tackle the FIA World Endurance Championship (WEC) including the 24 Hours of Le Mans as well as the American IMSA Weathertech Championship. The new racer will celebrate its debut under the toughest conditions at the IMSA season opener in Daytona on 28-29 January. “We’re very well prepared for this,” says Marco Ujhasi, Head of GT Works Sport. “Since its first rollout in Weissach in March this year we’ve covered 35,000 test kilometres on racetracks in Europe and North America – that’s more than in the development of any other Porsche GT racer.”
Technical data Porsche 911 RSR model year 2017
Concept
Single-seater race car for the LM-GTE category
Weight/dimensions
Weight ca. 1,243 kg (base weight per regulations)
Length 4,557 mm (without splitter, rear wing, diffuser)
Width 2,042 mm (front axle) / 2,048 mm (rear axle)
Wheelbase 2,516 mm
Engine
Water-cooled six cylinder boxer, positioned in front of the rear axle; 4,000 cm3, stroke 81.5 mm, bore 102 mm; ca. 375 kW (510 hp) depending on restrictor; four-valve technology; direct fuel injection; dry sump lubrication; single mass flywheel; power output limitation via restrictor; electronic throttle.
Transmission
Six-speed sequential constant-mesh gearbox; two-shaft longitudinal layout with bevel gear; shifting via electronic shift actuator; shift paddles on the steering wheel; magnesium gearbox casing; multi-disc self-locking differential with visco unit; three disc carbon race clutch.
Body
Weight-optimised chassis in combined aluminium steel design; removable roof hatch for cockpit access; lifting bushes integrated in the roof; FT3 fuel cell in front of the car; welded-in roll cage; seat pursuant to FIA 8862-2009; rigidly mounted to the chassis; six-point safety harness for use with HANS; longitudinally adjustable pedalry; bodywork made of CFRP, quick-change; rear wing with “swan neck” mounts; four-post air jack system with safety pressure valve; electronically activated fire extinguisher system; heated windscreen.
Suspension
Front axle: double wishbone front axle; four-way vibration damper; twin coil spring setup (main and helper spring); anti-roll bars, adjustable by blade positions; electro-hydraulic power steering
Rear axle: integrated rear axle subframe with double wishbone axle; four-way vibration damper; twin coil spring setup (main and helper spring); anti-roll bars, adjustable by blade positions; electro-hydraulic power steering; tripod drive shafts.
Brakes
Two independent brake circuits for front and rear axle, adjustable via balance bar.
Front axle: One piece aluminium six-piston racing callipers with quick coupling; internally ventilated steel brake discs, 390 mm diameter; race brake pads; optimised brake cooling ducts.
Rear axle: One piece aluminium four-piston racing callipers with quick coupling; internally ventilated steel brake discs, 355 mm diameter; race brake pads; optimised brake cooling ducts.
Wheels/tyres
Front axle: One piece forged light alloy wheels, 12.5Jx18 offset 25 with centre lock nut; Michelin slick 30/68-18.
Rear axle: One piece forged light alloy wheels, 13Jx18 offset 37 with centre lock nut; Michelin slick 31/71-18.
Electrics
Cosworth Central Logger Unit; CFRP multi-functional steering wheel with integrated display; shift paddles and quick release; Collision Avoidance System; controlled alternator in connection with LiFePo4 battery; LED headlights; LED taillights plus rain light; illuminated car number and leader light system; black light inside cockpit; electric adjustable wing mirrors with memory function; tyre pressure monitoring system (TPMS); drink system; air conditioning system; membrane switch panel on centre console with fluorescent labelling.
Old 11-16-2016, 06:56 PM
  #74
Ritter v4.0
Ritter v4.0's Avatar
Put another way; they didn't move the engine forward- they moved the chassis backwards with the transmission flipped to accommodate.
Old 11-16-2016, 07:11 PM
  #75
Jabs1542
Jabs1542's Avatar
Originally Posted by ApexComp
Not a turbo.
This was an interesting statement:
"The rules are written in a way that gives turbos and normally aspirated engines the same power and torque behavior,” he said.
Quick Reply: New mid engine RSR testing video
